2 hours ago, Jmonty said:
Any drone? How much louder did it get?
There is a little, I'm not sure if it's any different than the GM Cat back system. It doesnt bother me at all. I kept the flapper valves just in case and I have no intention of welding them back on.
I just put on the GM cat back system this morning...really solid. I can't compare it to what people are getting by just replacing the muffler and cutting out the flappers, but I will say that I'm really impressed. Lots of balls when you're into the throttle, very subdued at highway cruising speeds (I suspect this is largely due to the 10 speed keeping a low RPM when you're not passing somebody).
Great balance. Went on super easy.
I have been contemplating the GM cat back and installing it myself.  When you removed the OEM exhaust, did you have to cut it to get it out?
Ok, so we got it out without cutting it, but this was on a lift with two people manipulating the exhaust back and forth. It takes a little tetris/gymnastics to get it out of there in one piece, but it is 100% doable. On the ground or on jackstands? I'm not sure I would have bothered trying to get it out in one piece.
Of course, once we got it out and realized how long it was, and I had no easy way to transport it (and no real potential to sell it, it's likely going to end up at the recycler), we ended it up cutting it just past the second flapper so I could stick it all in the bed of my truck.
My advice would be to just cut it out with a sawzall, one cut will make pulling the old one out 10x easier. And then the new one goes in exactly as you would expect it to. There aren't any instructions in the box (other than to consult the official accessory service manual, AKA have your dealer do this), but you really don't need any, it pretty much fits together and hangs perfectly. Keep the existing clamp from where the flex pipe connects up toward the front, you'll reuse that one, everything else is in the box.
Edited by SierraAT4
  • Thanks 2
How loud is the performance exhaust in the backseat when you are pulling a trailer and the engine is running between 2600-2800 rpm?
On 3/18/2019 at 8:36 PM, SierraAT4 said:
This video convinced me to buy one:
Thanks for that.   I hadn't seen it before, but it consistent with the difference I saw when adding the exhaust and cold air intake.   My understanding is that it is the Borla exhaust branded as GM.  $2,000 for both installed, but a nice upgrade.
On ‎2019‎-‎03‎-‎21 at 9:44 AM, brothernov said:
Would it make any sense to only add the cold air intake, or only the exhaust?  As I type it it feels like a dumb question, if I increase the air in I'll probably need to increase the trucks ability to expel it, but I know practically nothing about exhaust systems.
Yes. This is what I do with my personal trucks. I put a cold air intake in them and leave the exhaust stock. That way, I only hear the engine noise under load, under normal driving conditions it is silent. This allows me to go on long drives with ZERO exhaust drone. I had a Magnaflow muffler in my 2010 and it was droney, I would end up with a migraine after a 4hr drive. This has been my method ever since to get some noise, hear your motor, but not be droned out so much you hate driving your own truck.
1 hour ago, bshort said:
Who's got the best price on the GM exhaust?
When I bought mine it was shop Chevy parts dot com
Yup. They have a 5% off promo code at the bottom on the site too. Shipping is the only wild card. It was very reasonable for me but if you’re far away it may wind up costing more than ordering at the dealer and having it sent to them.
Just noticed the little silver "performance" badge mixed in with the paperwork that comes with the performance package.  Anyone stick this on their truck?  I'm curious where you put it.  I won't be using mine, it has a Chevy Logo on it, I've got an AT4 :cool:
Test drove an AT4 yesterday with a 6.2 and performance package. Just barely louder than my current 2010 with a 6.2, 3.73 gears, stock exhaust, and K&N CAI. Couldn’t notice sound at all unless I punched it a little. It did seem a little more responsive to the throttle than mine. I went ahead and put my order in!
    LCH14
    LCH14
  • Who's Online   5 Members, 0 Anonymous, 962 Guests (See full list)
    • I'd change the fluid and start there.   198F is nothing for the 8L90.  They typically operate 180-200F stock.
    • Looking for help!   2019 GMC Sierra 1500 - 5.3l 4x4 8l90 61k miles - truck is in Arizona, was over 110 outside on Monday when this whole situation transpired. Never had any major issues with transmission until this point:   Truck sat outside my construction office for approx 1 hour idling before I realized, ran around the job site wrapping some things up for the day and then left. Went to get food and sat in the drive through for approx 30 minutes idling. As soon as I pull out of the drive through and onto the main road, rear tires lock up and feels like transmission fell out of the truck. Shifted to park, shut the truck off and tried again, same thing happened. Was able to reverse into parking lot (truck slammed into reverse). Let the truck sit turned off for 10 minutes before trying again, but it continued to happen. Towed truck back to my house. Highest the trans temps reached was 198.   Friday, after work I start looking into the situation. Truck sat in my driveway untouched all week. Truck is now driving like normal, transmission doesn’t get over 185 degrees when trying to heat it up. Got up to 60 multiples times with no issues, no issues accelerating, only down shifted hard into first one time at 185 degrees. Does anyone have any insight? Never through a code or a check engine light. Truck has never been used to tow either. No transmission services at this point.
    • Atlas won.   I know better, but I did it anyway. I took a compressed air line with a chuck and rubber tip and jammed it in the open EGR port. The port was clear as far as I could see, and as far as I could poke with a flexible wire, but that doesn't mean it's not clogged.   Compressed air blew back at me along with a cloud of black. Oops. I didn't have the rubber tip seated in there all the way. Jammed it up in there some more and squeezed the chuck. PSI was set to 120. Poof! It blew back at me again. Third time...pfffffttssssssspffffffsssfffffff, face full of carbon, and then, kind of a thud..and the air stopped spraying back at me. It was now exiting the exhaust with a low shhhhhh sound as it flowed through the pipe. Something broke free. I pressurized the port again, and air flowed.   Made my day.   Long story short on this problem, it's fixed. Something was really blocking the EGR passages down low, and compressed air blew it apart. I don't recommend this as who knows what debris was sent where. But it's allowed me to move forward, mentally, and onto the next problems I need to get this little S-Blazer going down the road properly again.
    • Your truck lowered, looks good. I'm happy with the stance on this. I may need the extra ground clearance given my location/situation.
