14 hours ago, Thejet07 said:
Just got a call from gm and they told me buyback not approved by district manager until field engineer looks at it. Wtf, I’ve been waiting for weeks to have the engineer look at it. Wasting my time and dragging things on. I’m pretty sure I’m over the 30 days required by my state law and the truck is still going to have multiple repairs done to it the next time it’s in the shop. Ohhhh the games they play
Lemon law it.
Lemon Law it...
agreed lemon law time imho
Didn't read all 37 pages, but this just came out Aug 6th.  Check bulletin PIP5653B.   "Some customers may comment on a squeak or chirp noise in 2wd that goes away in 4wd.   Bulletin is to replace left axle output shaft.
Yup that's the "fix" that everyone has been getting done that's not fixing anything.
OK, sorry, I should have read through it.
1 hour ago, Sin City Trail Boss said:
All good. Just giving you a heads up that it hasn't really helped much for most of us.
Thanks.  A couple of the people I've heard complain about this have said the noise has diminished somewhat over time.  Not that that's any consolation.
Trucks going back in next Tuesday. Technical assistance advised to replace some more parts. I will find out what they are. Hopefully, while it’s in there they will take care of the rest of the problems I’m having. I think they’re gonna offer me an extended warranty and money. I thought about it long and hard and decided I’d probably take it. By the time my warranty is up I’d probably trade it in by then so I’ll never have to worry about repairs during the interim. We shall see
Picked my truck up on Tuesday as the parts to be replaced are on back order and will take at least 20 - 30 days to arrive at the dealer. The parts they intend to replace are as follows: 84428312 - Ring, 84428310 - Seal, and 84428295 - Slinger. No idea what a "Slinger" is.
Yup, those parts are the supposed “fix” that nobody has had any luck with. Many have had this fix done, none have been successful in solving the problem.
Thanks for the additional info.
oil/fluid slinger, small rotating disc - typically rough-surfaced.
Opposite for me, I had Gm’s fixed done, didn’t fix a thing. And as the miles go up, it seems to be getting louder.
On 9/17/2019 at 6:35 AM, ct_corey said:
Lemon law it.
Currently dealing with the same problem. However gm claims it isn’t a safety issue. But they don’t know what’s causing the sound. Well how do they know it’s not a safety issue then? I told them if they can’t figure something out soon, lemon law time.  30+days at dealer. Multiple issues.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,185 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
