First time towing with the new rig.  600 miles round trip to Niagara Falls, ON for Memorial Day weekend.  The 6.2 had plenty of juice and I'm quite pleased overall.  Coming from a 2500 Duramax I was concerned.  The camper is about 7000 lbs and 33'.  We used a Husky Centerline TS weight distribution hitch.  We averaged 10.5 mpg on the way there with 93 octane gas.  The highest octane I could find in Ontario was 91 so that's what we used on the way home and we averaged about 10.0 mpg.  Those were the computer numbers but they were higher than I expected.  I didn't hand calculate though I may next time just to make sure they're accurate.
All things considered, we're very happy with the downsize.
Hahaha got a pick in front of a tim hortons. I know nothing about Canada in general but I know about Timmy's.
Sent from my ONEPLUS A6013 using Tapatalk
Not much for Blanco to tow.
Going from Bay Area,CA to Seattle, WA. Towing a 6x12 uhaul trailer. Empty going up. Full going back.
I will be documenting the mpg for all.
The Bay Area, CA to Seattle, WA.
830 miles one way. Came back, Blanco has 5500 miles now.
Was getting anywhere from 11-15 mpg on average doing 65-72 mph on a "closed course" empty or full. The trailer is a brick.
Edited by BlancoSilverado
Anyone out there have any issues with the trailer wire hookup on their truck?  I got a 2019 high country with the max towing package. Hooked up to the trailer and had no power going to the hookup. Trucks been in the shop for almost 2 weeks and they can’t figure out what’s going on.  The dealership has told me they have already replaced two different modules and it still never fixed it.  I just keep getting told that because it’s a new model there not much information on them to troubleshoot easily witch I do get but hate owning a truck I haven’t been able to drive and the truck was 6 weeks old on Saturday. Not impressed one bit.
On 2019-05-02 at 3:24 PM, Limelight said:
You win the entire internet for towing the entire house.  Lolol
Then ya know a thing or two about coffee....☕️  Mac Donald's up here in Canada is really giving Tim’s a run for there money...
As mentioned above, yes, the 6x12 uhaul is a brick.  Hauled it 1100 miles, medium load - this was the weekend before Memorial Day.  Half of the drive was on I-40, the rest went up through panhandle of texas, new mexico, colorado and across the continental divide at 11,200 feet.   The 6.2 pulled it wonderfully, love the 10 speed.  I too came from a 2500hd/duramax, but this one did very well.   However, the mileage dropped as low as 10mpg and as high as 14mpg in the higher elevations running slower, but I ran it on tow haul most of the ride and I was giving it h*ll down the freeway running mid grade fuel.
Edited by bcato
Is that the 2800BH? How do you like it? Looked at one a few times but have been hesitant to pull the trigger with my 17 Sierra 5.3.
Do these trucks squat quicker than the K2s? From some of the pics I feel like they do.  Could also just be the way the weight is distributed at that given moment from the angle the rigs are parked at.  Or maybe its the body lines/circular wheel wells making it look that way.
I think they do. I loaded a lot of bags of dirt in my at4 and it squated easier than previous trucks. I’m sure if a trailer with a proper weight dist. hitch was hooked up it would do much better.
14 minutes ago, Unclebud87 said:
I think it varies from the package. The at4 and trailboss have quite a bit lower payload and tow capacity.
Worried about this as well as the AT4 is what I want to replace my 16 AT, but my 16 hardley sags at all
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 552 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
