First time towing with the new rig.  600 miles round trip to Niagara Falls, ON for Memorial Day weekend.  The 6.2 had plenty of juice and I'm quite pleased overall.  Coming from a 2500 Duramax I was concerned.  The camper is about 7000 lbs and 33'.  We used a Husky Centerline TS weight distribution hitch.  We averaged 10.5 mpg on the way there with 93 octane gas.  The highest octane I could find in Ontario was 91 so that's what we used on the way home and we averaged about 10.0 mpg.  Those were the computer numbers but they were higher than I expected.  I didn't hand calculate though I may next time just to make sure they're accurate.
All things considered, we're very happy with the downsize.
Hahaha got a pick in front of a tim hortons. I know nothing about Canada in general but I know about Timmy's.
Sent from my ONEPLUS A6013 using Tapatalk
Not much for Blanco to tow.
Going from Bay Area,CA to Seattle, WA. Towing a 6x12 uhaul trailer. Empty going up. Full going back.
I will be documenting the mpg for all.
The Bay Area, CA to Seattle, WA.
830 miles one way. Came back, Blanco has 5500 miles now.
Was getting anywhere from 11-15 mpg on average doing 65-72 mph on a "closed course" empty or full. The trailer is a brick.
Edited by BlancoSilverado
Anyone out there have any issues with the trailer wire hookup on their truck?  I got a 2019 high country with the max towing package. Hooked up to the trailer and had no power going to the hookup. Trucks been in the shop for almost 2 weeks and they can’t figure out what’s going on.  The dealership has told me they have already replaced two different modules and it still never fixed it.  I just keep getting told that because it’s a new model there not much information on them to troubleshoot easily witch I do get but hate owning a truck I haven’t been able to drive and the truck was 6 weeks old on Saturday. Not impressed one bit.
On 2019-05-02 at 3:24 PM, Limelight said:
You win the entire internet for towing the entire house.  Lolol
Then ya know a thing or two about coffee....☕️  Mac Donald's up here in Canada is really giving Tim’s a run for there money...
As mentioned above, yes, the 6x12 uhaul is a brick.  Hauled it 1100 miles, medium load - this was the weekend before Memorial Day.  Half of the drive was on I-40, the rest went up through panhandle of texas, new mexico, colorado and across the continental divide at 11,200 feet.   The 6.2 pulled it wonderfully, love the 10 speed.  I too came from a 2500hd/duramax, but this one did very well.   However, the mileage dropped as low as 10mpg and as high as 14mpg in the higher elevations running slower, but I ran it on tow haul most of the ride and I was giving it h*ll down the freeway running mid grade fuel.
Edited by bcato
Is that the 2800BH? How do you like it? Looked at one a few times but have been hesitant to pull the trigger with my 17 Sierra 5.3.
Do these trucks squat quicker than the K2s? From some of the pics I feel like they do.  Could also just be the way the weight is distributed at that given moment from the angle the rigs are parked at.  Or maybe its the body lines/circular wheel wells making it look that way.
I think they do. I loaded a lot of bags of dirt in my at4 and it squated easier than previous trucks. I’m sure if a trailer with a proper weight dist. hitch was hooked up it would do much better.
14 minutes ago, Unclebud87 said:
I think it varies from the package. The at4 and trailboss have quite a bit lower payload and tow capacity.
Worried about this as well as the AT4 is what I want to replace my 16 AT, but my 16 hardley sags at all
    • Can anyone explain why the oil pressure runs higher after the DFM is shut off?  just installed the Pulsar Lt.
    • Thanks!  I figured as such; GM and other manufacturers have used standard parts and harnesses across trim levels and such for decades.  I pulled the blank accessory cover off of my commuter van (a 2016 or so Chevy 15-passenger) years ago and found the plug for a USB outlet.  It wasn't connected to anything, though (I tried swapping in an outlet from another van).  I was a GM Tech years ago (late-90s) and was pretty familiar with my 2006.  I might be wrong, but I view newer vehicles (pretty much anything made in the past 20 years) as being a lot more plug and play.  Meaning, more unused wires and plugs unless you have the Mack Daddy of vehicles.
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
