we have had 5 days of rain, creeks are rivers and a lot of farmers fields are under water. yesterday afternoon we finally got some sunshine and 72 degrees, short lived, today more rain and sunday it is supposed to snow
Got 2 inches, 16 degrees this morning.
14 hours ago, OnTheReel said:
Another whacky weather week up here. Tornado warnings in 4 of the last 5 days. Phone alert at 1:38 AM for the first one took a few years off my life. The others have been in the late evenings. Thankfully no damage. Just lots of rain. We had already exceeded the monthly average in the first 7 days. Not sure where we stand now but has to be a record.
I’m sure @Grumpy Bear has been seeing similar crap down by him. Tonight’s band was 1000 miles wide…
We had basement time. Not fun as the wife just had a hip replacement and stairs were not on her bingo card. Rain, wind, hail and twisters. YUCK. Still our property has faired better than many. We spent heavy last year on water abatement and it has already paid for itself. Basement is as dry as can be. Roof looks good and we lost no glass. Big upgrade.
We were out of the tornado warning by 10 pm last night but the rain kept up for a few hours more and the thunder was deafening at times.
As of this morning we've had but three days this April without rain. We have twice our monthly average at 6.09 inches. This is keeping the sump pumps busy and the grass by the bubbler watered to death; cutting a ditch in the turf. Better than in the basement. More is forecast for later this week but we are getting a few dry days. Those few are recording sub freezing temperatures over night killing off early sprouts.
I have to say the lawn has never looked better and I've mowed a summers worth already. Glad gas is cheap :crackup:
25 yesterday morning, 30 today. Snow flurries and windy yesterday. Been windy for days.
We got 7 inches 30 degrees this morning.
You need the moisture
I forget; how high are you guys? BTW...how's the wife doing?
9200 feet Grumpy. We got 18 inches over 2 1/2 days, 19 degrees today.
Wife is doing ok. Her eyes will never be the same but it could be worse.
Thanks for asking.
Forecast of up to 14 inches next 2 days.
3" of rain yesterday in 30 minutes. 2" 24 hours earlier and we are getting another storm that say  is larger today in about 2 hours.
We had about the average for April, a very VERY dry May and now I'm hoping to see a rainbow in June. Corn is loving this stuff.
    • I agree.   However, the owner's manual, suggests that a drop over full is just as bad as a drop under. (Read black and white letters only, insert no common sense.)
    • That P0700 and loss of power suggests something significant is amiss to me.   More/other codes may suggest otherwise; I would investigate those prior to spending the money to change fluid on a transmission with a bad torque converter.    The relatively sudden escalation of symptoms to me suggests that something began failing (initial shuddering experienced) and rapidly deteriorated (slipping/loss of power). Fluid condition alone wouldn't cause the sudden escalation of problems - though it might have been the cause of the deterioration up to the point of failure.
    • Stabilitrack operation is in a sense a separate/independent operation from the operation of 'traction control'. Stabilitrack is used to keep the vehicle traveling in the DIRECTION intended, it can brake independent wheels and or adjust throttle to influence the direction the vehicle is moving.   This can be illustrated by a 'fish-tailing' example. At high speeds, if the stabilitrack detects excessive yaw (the vehicle spinning like a top, it has a sensor for this), based on inputs from steering angle it determines that the vehicle is spinning out of control, and begins working to control that unintended spin. By reducing throttle input or braking specific wheels to control or prevent the spin.   The traction control works similarly using the ABS system to slow spinning wheels and thus transfer power to 'other' wheels. The goal being to achieve wheel speeds that are all in agreement with each other, the truck then assumes that since all the wheels speeds are the same no spinning is occurring. For example, launching up a wet boat ramp, there is no excessive yaw present, traction control alone can manage the wheel spin by braking spinning wheels and cutting throttle.   Stabilitrack and traction control from a hardware and software standpoint are basically one in the same, I don't remember specifically in 2004, but you couldn't get a truck with one and not the other. The switch on the dash, could turn off the traction control, but not necessarily the stabilitrack.    A confusing comment about stabilitrack vs. traction control, the same components serve both operations, but marketing could advertise them as two separate features.    The AWD system is another separate system entirely, in addition to the other two, it uses the same wheel speed inputs but can also vary the transfer case clutch application to direct some power to the front axle, working in conjunction with the traction control to bring wheel speeds together.   The power split will never be greater than 50:50, the same as 4-high. It will never direct MORE power to the front axle than the rear.
    • Not based on the new photos I'm seeing.  Car and Driver posted additional photos that shows an auto stop start button left of the steering wheel.
    • Car and Driver is reporting wireless CarPlay WILL remain, and they posted several additional photos, including a left knee shot, but the only hard buttons there are e-brake, auto start stop, tailgate and cargo light.  Also definitely looks like High Country and ZR2 get micro fiber on the center of the console lid and the ZR2 possibly also on the seats.
