Anyone done helper bags? I put my wheels and tires on yesterday and have decided I’m going to level with a 1.5” rear drop using Wulf Suspension shackles for my 2020 RST.
I always have a trailer hooked up to the truck and I think I’ll def need helper bags to obtain a desired travel position.
Edited by Nico23
Accidentally submitted before I typed it all out (;
Leveled my 20 Elevation, ready to fill those gaps with some new tires. [emoji2371]7d9b14dc44b9b965ff83b473a65fd95a.jpg
I have bags on mine for pulling my RV. Also have an wireless One On-board compressor for quick, easy adjustments. Highly recommend. Easy install. Wouldn’t tow with air bags. Have had then in my last 3 trucks for towing.
Nice, do you recommend a particular brand? I also pull a 28’ (5500lb) travel trailer.
Could you also point me in the direction of that wireless compressor? I’d like to eyeball that! Sounds like the exact route I’m wanting to go.
I pull about the same trailer.
I have these airbags:
https://www.airliftcompany.com/shop/89288/
And this compressor:
https://www.airliftcompany.com/shop/25980ez/
It’s a nice set up. Really like being able to adjust the pressure as I go. Easy for hooking on and unhooking, etc. Definitely worth the $ if you tow lots. I tow every 2nd weekend or so. Wouldn’t go without this set up.
Greatly appreciate this. Yes sir I’m with you, I tow every weekend. I’m going to jump into this asap.
First thing would do is add a weight distribution hitch for your travel trailer - will eliminate most of the rear drop and be a safer tow set up tranfering the tongue weight back to your front wheels.
I have thie set up for my enclosed trailer which is 4,350 empy and pending load will be 7,300 or 9,500 lbs.  Droop without it was 2.5" - now with proper adjustment it is about an inch.
Air bags make for better ride - keeping rear from harsh bounes off the bump stop - but do nothing for tranfering tongue weight from hitch to the front wheels of the truck.
I would also recommend a sway control for anything heavier that 7,000 lbs and longer than 20'.  When things go wrong the the tail wags the dog and both weight distribution and sway control will help you keep the upper hand.
I have husky weight dist hitch.
link:  https://www.amazon.com/Husky-31425-Weight-Distribution-Assembly/dp/B0085IHWF0/ref=sr_1_6?dchild=1&keywords=Towing+Weight+Distributing+Hitches+1%2C400+lbs&qid=1598316429&s=automotive&sr=1-6
Sway Control
Link: https://www.amazon.com/Husky-34715-Handed-Adjustable-Control/dp/B004RCT0LM/ref=pd_bxgy_img_3/145-5324336-5112768?_encoding=UTF8&pd_rd_i=B004RCT0LM&pd_rd_r=45138ec8-39e1-49b1-964c-4a5efbfcea95&pd_rd_w=3aNy8&pd_rd_wg=59lSx&pf_rd_p=ce6c479b-ef53-49a6-845b-bbbf35c28dd3&pf_rd_r=Q3S4JQCAX0FBXDQJZE1P&psc=1&refRID=Q3S4JQCAX0FBXDQJZE1P
Here is an intersting video that will give you a clear picture of how weight distribution vs air bags impact your truck.
Link: .
Nice truck - good luck with your set up!
Sway Control
Link: .
[/url]
I use a WDH hitch as well, always have towing anything 5k or more. It’s common sense to use one, or should be. Air bags add that extra help on the ride, bounce, sag, etc.
On 10/2/2019 at 2:38 AM, 2019 Sierra Me said:
Here is 3" kit on my 1500 Sierra. It now measures right at 40" in front and 42.5" at rear with the 33" tires,285/70/17" to the
Bottom of the wheel wells. Sits about the same as factory 2500HDs. Not even close to rubing anywhere. Rides and handles nicely. Get alot of " oh you bought a 3/4 ton?" Comments all the time. I am pretty sure 35" would have worked just fine. But I didnt want
to loose that much mileage.
Looks great!
How is the 3" working for you?  I am looking to put a 3" front 2" rear on my 2020 Sierra, however the shops are recommending not going over 2.5" front on the 19/20 MY.
RC 1.5 front level kit.  The 2 inch level on Trail Boss requires new control arms and X 3 times the price.  Rake is less than 1/4 inch with the 1.5 RC and is close enough for me.  Tires = Nitto Ridge Grapplers 295/70/18 that measure 34.3 inches diameter.
Just wondering why all the truck leveling? Is there a practical reason or is it  just aesthetics ? If it is actually better does GM or any other truck manufacturer offer it as an option?
Simply for looks. Factory puts a rake on the trucks to counter the rear squat while towing/hauling heavy items.
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
