STR OOFF-ROAD STR 84 20X10 0+
Delinte DX-12 285/55R20
No spacers (yet?)
Slight rub in reverse at full lock
Edited by psychocadi
Add wheel brand
I went with some Walker Evans Bead locks on some bfgs. I have no rub, spacers, she clears brake calipers but just by a hair.
17x9 walker evans racing forged bead lock with some special engraving.
315,70,17 BFG ko2
CST lift at about 2 inch
Edited by Fermy
Forgot brake clearance part
315,70,17 BFG ko2
Looks sick man. Always a fan of more tire less rim. Been running that same tire for a little over year on my truck and the wife’s Yukon. 0 problems and they’re wearing very nicely. Super quiet and ride very good being a C rated tire.
Dub Luxe 22x9.5 +20 in gloss black with Ridge Grapplers 285/50
Readylift 2” leveling kit
Edited by grrr027
  • Like 6
Fuel Vapor 20x10
Nitto Ridge Grappler 35x12.5
4” Zone suspension lift on top of factory TB 2” for a total of 6”
minor trimming of the wheel well
  • Like 5
Nice! Look I'm going for without the lift, love the wheel design and black on black
18X9 Fuel Maverick w/ 33X11.5 Nitto Terra Grapplers
Readylift +2 SST lift
No rubbing at all, I have a set of 35" Ridge Grapplers I may try on but I'm pretty sure they won't fit without a lot of trimming.
I would love to know if the 35s fit. I see people that say they do. I am ready to place an order for new tires and wheels but unsure what I can stuff in there.
I need some help from the group. I’m ready to pull the trigger on new tires and wheels. I have an AT4 with a 2” Readylift level on it. I would like to go with 35s with 20x10-25. Does anyone have this setup?  I talked to Custom Offsets and they thought they would work if I trimmed the mud flaps. But I would like to hear from the experts here.  Also if someone has this setup where did they rub?  I do have a FabFour bumper so I have extra clearance in the front.
I had Toyo Open Country AT3's installed about an hour ago.  Already much better than the OEM Michelins.  I wanted to keep the stock 18's (budget) and stock 265/65/18 size but wanted more aggressive looking tires that were not too loud, handled better in turns and were good in snow and on dry.  I don't do much off-roading but I had used K02's on my previous Jeeps.  Decided to try something new with the Toyos (they were 10 lbs lighter).  So far I'm impressed (only put about 20 miles on them).  Improved the look and driving dynamics quite a bit.  The ride is a little more firm and less "bouncy" which I like.  Just overall more composed.  If you're in the market, I recommend checking them out.
Edited by Mike Borowski
I'll be glad to share some feedback on some of the builds we've done. Ok so even with the 2" Readlift on top of the factory lift our customers have experienced some decent rubbing when running 35"s with 10" wide wheels and negative offsets. You'll need to trim some plastics (see below) and also from the feedback I've gathered some metal as well. Regretfully we have done one locally they have all been out of state customers so I don't have images of the metal trimming required. I have heard from some customer that with the 20x10 -18 they got away with the below trimming only but I can't confirm that.
Today we're test fitting 35" tires on 20x9 wheels with your exact same lift feel free to email me at admin(@)wheelsasap.com if you like and I'll share my finding with you. After that test fit I'd have a better idea of any challenges you'll be facing.
Trimming guide: https://wheelsasap.com/gmc-at4-oversized-tire-trimming-guide/
Fuel Maverick D610
20x9 +20
nitto ridge grapplers 275/60r20
stock z71 suspension (only 3/4” of rake)
*No rubbing
    LCH14
    LCH14
  • Who's Online   1 Member, 0 Anonymous, 1,235 Guests (See full list)
    • Yea a fluid change is in order here. Honestly, your transmission didn’t even get hot. During the summer in stop and go traffic I’ve seen my 8l80 get up to 216 and it was still shifting smoothly.
    • I'd change the fluid and start there.   198F is nothing for the 8L90.  They typically operate 180-200F stock.
    • Looking for help!   2019 GMC Sierra 1500 - 5.3l 4x4 8l90 61k miles - truck is in Arizona, was over 110 outside on Monday when this whole situation transpired. Never had any major issues with transmission until this point:   Truck sat outside my construction office for approx 1 hour idling before I realized, ran around the job site wrapping some things up for the day and then left. Went to get food and sat in the drive through for approx 30 minutes idling. As soon as I pull out of the drive through and onto the main road, rear tires lock up and feels like transmission fell out of the truck. Shifted to park, shut the truck off and tried again, same thing happened. Was able to reverse into parking lot (truck slammed into reverse). Let the truck sit turned off for 10 minutes before trying again, but it continued to happen. Towed truck back to my house. Highest the trans temps reached was 198.   Friday, after work I start looking into the situation. Truck sat in my driveway untouched all week. Truck is now driving like normal, transmission doesn’t get over 185 degrees when trying to heat it up. Got up to 60 multiples times with no issues, no issues accelerating, only down shifted hard into first one time at 185 degrees. Does anyone have any insight? Never through a code or a check engine light. Truck has never been used to tow either. No transmission services at this point.
    • Atlas won.   I know better, but I did it anyway. I took a compressed air line with a chuck and rubber tip and jammed it in the open EGR port. The port was clear as far as I could see, and as far as I could poke with a flexible wire, but that doesn't mean it's not clogged.   Compressed air blew back at me along with a cloud of black. Oops. I didn't have the rubber tip seated in there all the way. Jammed it up in there some more and squeezed the chuck. PSI was set to 120. Poof! It blew back at me again. Third time...pfffffttssssssspffffffsssfffffff, face full of carbon, and then, kind of a thud..and the air stopped spraying back at me. It was now exiting the exhaust with a low shhhhhh sound as it flowed through the pipe. Something broke free. I pressurized the port again, and air flowed.   Made my day.   Long story short on this problem, it's fixed. Something was really blocking the EGR passages down low, and compressed air blew it apart. I don't recommend this as who knows what debris was sent where. But it's allowed me to move forward, mentally, and onto the next problems I need to get this little S-Blazer going down the road properly again.
