OEM wheels with Falken Wildpeak LT275/70R18.  Had these on with OEM Racho's prior to adding Bilstein's last week in Front/Back as displayed below.  Love how they work in the snow and stay nice and soft compared to BFG ATs.
Edited by RSVolcom
7 minutes ago, Thejet07 said:
I’m torn between getting the falkens or the toyo open at3. I assume no rubbing?
None for mine at stock with LT275/70R18.  Are the toyo open at3 winter rated like the Falkens?  Are you look at the Extreme Toyo or regular?
Edited by RSVolcom
The toyo open country at3 are the ones I’m looking at. I’m assuming they are the regular ones. They are snowflake rated now which is what got me interested in them. They are around the same price as the falkens which is making it very difficult for my indecisive self to decide. Do you feel the added weight difference has made an impact in any way? I believe the toyos are 8 lbs lighter making it more appealing
I've had them both you can't go wrong with either. Still have the Falkens on my wife's 4x4 van and had the at2 & at3 on other trucks.
Thanks to a bunch of posts on here and a bit of luck I went with my my set up.
21 At4 stock lift no level, no spacers, no trimming or rubbing. A bit stiffer ride than duratracs due to squarer profile. Super happy with less rocks being flung down gravel and reduced tire hum.
method 17x 8.5 0 offset
Toyo AT3 285/70-17
Edited by Yfz43gmc
Updated review
  • Like 4
Fuel reaction D755 20x9 +1 offset
285/60r20 falken wildpeak
no spacers needed
zero rubbing
Anyone have a pic of 275/60r20 Toyo AT3 on stock wheels? I’ve been thinking about running them over the RG..Also had Whildpeaks in the back of my mind. Always had lifted trucks but wanting to keep this one closer to stock just with better AT tires
22 hours ago, 1454 said:
On 3/26/2021 at 5:47 PM, Presley said:
I really like that red and black. I'm a big UGA fan, so it matches my theme. Lol.
I didn’t realize when I posted but those photos don’t do these wheels justice
Oh wow, that original pic really didn't do it justice. Those are awesome.
GM replica 24s.
Truck is leveled for now.
I have a rear 4 inch drop in the garage as well as 2 inch drop struts
45 minutes ago, Gwill30 said:
GM replica 24s.
Looks good. Delete those mud flaps and front valance and it will be perfect.
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
    • It would be sold as a "kit", lights + auth/programming code.   You can resell the code to someone else, if they just buy the lights, either new or used, and they can then use the code to get them to work on their truck.
    • Apologies in advance, this is a long post, there's a lot to explain.   A friend had a 2010 Avalanche with a 5.3 (LMG) that blew the head gaskets (amount other problems). He gave me a donor motor out of a 2007 suburban (LC9). I got it all installed, and everything hooked up. Went to go start it, and it stumbled a bit at first and died a couple times, but after trying a few times it sounded like it was running very well. Went out to go get some coolant, and came back the next day.    Upon trying to start it, the truck will crank and fire normally and the RPMs will raise to around 1,200 or 1,500, sounding great, and then the RPMs will decrease and it will just die. Repeat that a dozen or two dozen times, and eventually it will fire and idle beautifully. As soon as you touch the throttle, it will start misfiring and sound like absolute trash. When you let off the throttle it will come down and hunt around shaking and misfiring like crazy. A message will come up on the dash saying reduced engine power.    It is throwing codes for a map sensor circuit voltage High, as well as MAF sensor low frequency. With key on engine off, the map sensor reads about 4.8 volts on the vout pin, which the PCM interprets as about 17.8 PSI, contrasted to the barometer which my scan tool tells me reads about 13.5 PSI. However, once the engine starts and is idling this reading drops to about 5-6 PSI at a stable idle, and varies significantly when the engine is misfiring/ hunting like I said before. I should note that I used the intake and MAP sensor from the LC9 engine. I changed the connector on the 2010 harness to The 2007 connector. The pinouts for the sensors were printed right on the top, and I triple-checked that I put the correct wire into the correct place.   On the other hand, the MAF sensor reads consistently 0.0 g/s regardless of State. I have pulled my hair out trying to figure out this last detail. I have tried three different sensors, (all of which should be good, one of which was new), I have verified all the wiring from the sensor going back to the PCM, and have verified that the readings at the PCM are the same readings as at the sensor itself. The intake air temperature sensor is also functioning as normal. I verified all the voltages and grounds etc, and everything is as it should be. I don't have an oscilloscope to verify, but I probed with my multimeter (Klein mm720) on frequency Mode, and it reads that on initial cranking, the maf is producing between 3000 and 7000 HZ, and as soon as the engine fires that falls off to below, 1000, and if the engine continues to run, it will produce somewhat erratic readings between 5 and 100-200 HZ. It does increase notably when the engine is revved despite the misfirings. As I said before, I have verified all of the wires going to the PCM, and I have tried multiple known good sensors. I've tested all the pins and voltages from the sensor and verified them against the manual that they are what they should be. I tested all the wiring for both ohms and voltage drop, and everything tested fine. Like I said I tested at the sensor as well as right at the PCM, everything checked out.   The only other thing of note at least I think is the fact that the engine originally in the truck had VVT, but the engine I put in, the lc9, does not have VVT. I modified the cam sensor plug to work. I reference the wiring diagrams and double-checked that I modified the harness correctly to adapt it. There is obviously a code for the VVT solenoid, but I don't think that's the cause of my problems, and this friend will probably have the PCM sent off to tune out the codes at some point.   I'm writing this for my bed so I don't recall the exact codes, but I'll update the post tomorrow morning with the exact codes. And ideas or feedback much appreciated.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
