6” BDS kit #1803H
Edited by Bgill
On 6/6/2021 at 3:05 PM, Tboykin51 said:
Have a 2020 1500 RST. Stock suspension. Looking at putting a 3.5” - 4” kit on the truck.. want to run an aggressive looking 35” tire on stock 20” wheels but don’t want serious rub.. anyone running a similar setup? Any pictures out there?
Just posted a pic with a similar setup. 4 inch Ready Lift with 35/11.5/R20
Anyone have pictures of an Elevation with non black wheels? I'm hoping to swap mine out on my cardinal red sierra.
Edited by Isuav8or
On 9/25/2021 at 10:39 PM, Billynstephanie said:
Went from 18’s to 20’s
What did you do with the 18"s??  Still have them?  Color, style, etc? Curious.
8 hours ago, Abacabb said:
No spacer was needed with this, right? Beautiful setup btw.
Correct. Thank you,
On 9/30/2021 at 8:33 AM, HotChiliRam said:
Stock height stock rims, just installed a set of 305/55 20 Toyo AT II, no rub but it barely clears the upper A arm.IMG_8622.thumb.jpeg.9895f6151866cbd199332e6376823523.jpeg
Welcome to the site.
Very nice truck, for some reason I really like the license plate too!!!
Thank you, why do you like the license plate??
Last week I installed a 2” lift, I think I’m going to a a inch more in the front and I already bought a set of 1,5” wheel spacers (Hub Centered).
like the shape compared to the USA versions, plus the letter number combo looks like it could be RPO codes for your truck.
On 9/8/2021 at 2:21 PM, putz173 said:
Fuel Beast 20" 285/60/18  +20mm offset (flush fit) , 21 trailboss, very very slight rub at full lock going in reverse touching the top edge of the mud flap, cut 2" of the flat pat of the flap inside the wheelwell off with a dremel and it stopped
I would like to see how you got a 285/60/18 tire on a 20 inch wheel.  😆
  • Haha 1
wheel spacers and blinker fluid
lol ill have to change that to 20
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
