I ran 18” E rated Terra Grapplers on my Tahoe and I couldn’t wait to tale them back off and sell them at a loss, the ride was so hard it was jarring, I’m really scared to run a E 22” with that much less of a sidewall, plus the extra rolling resistance due to the heavier tire, there is no benefit in running the E’s.
I’m looking at chrome wheels as an option but I’d rather stay with a polished wheel, I’d also like to stay with OEM too but worried about fitment with the front calipers.
Edited by eppieguy
Yes,.. there are not that many that seem to fit without spacers.. and I'm not a fan of spacers
285/55/22 - 34.5 inches
oem 22x8.5
36psi
-flush with fenders
-ride is much improved, noise is down
-lost about 2mpg vs oem 20s
-no level kit, stock suspension, no rubbing
no regrets, love the setup
Towed a couple loads around 9,000lbs no isssues, rock solid
posting this on my iPhone, no idea why shits upside down
Edited by PabloK
Hmmm...., Love the look, how is it on bumps on the road vs. the OEM 20's? I've run E rated tires before and have hated the ride, very concerned about losing ride quality, but I sure like the look.
Found my heavier Nitto Ridge Grappler tires do much better with high quality shocks versus stock oem shocks. In addition, airing them down a bit does help ride quality too.
The ride was improved in all aspects. Highway joints, transitions, potholes are really just soaked in now.
Around town and at slower speeds it feels great.. steering isn’t strained or affected.
I see a lot of folks running these massively wide tire setups which dramatically affect the ride and handling properties of these trucks.
I found that the 285 is the ideal width that still looks beefy, is perfectly flush with the sidewalk, and properly fits the rim.. it tracks perfectly on the highway, doesn’t pull or “follow” in road depressions from heavy semi use.
I ran psi numbers from 32 to 46 and I found that 36-37 was indeed the sweet spot for these tires.
Tires are a good $450 each but this is something you don’t cut corners on. Spent 4 months testing and dialing in this setup and it’s a 9.5/10.
Only con was the slight decrease in MPG.
I was also not able to tell any negative “performance” related effects from the added rotational mass... and I’m crazy about that.
Forget E-rated.. all that means is that the tire has the capability to run a higher PSI.
The make/model/design/engineering on the actual tire and the actual psi you run are what’s critical.
This tire was design to look meaty and ride nice on the road. It does that very well.
285/60/20’s right here: 257d374be97a8e2ba693e8ad6730b705.jpg
Thank you for your review, I’m much more comfortable getting E range tires based on your opinion. Now, to decide to pull the trigger on the tires or not, I’ll stay with the terra grapplers, they are giving $100.00 off today and tomorrow.
KO2’s come in D rated too, check them out too. If comfort is a priority then I’d avoid heavier oversized tires especially E rated. I’ve heard so so reviews on the Terra Grapplers but they supposedly came out with a new better version, just what I’ve heard. Good luck!
I’ve been running TG’s on all my trucks since 2004 and they have been great for me. BFG doesn’t make 285-55/22’s unfortunately.
[emoji1303]
Your welcome.
Just to confirm with you, the Terra is a totally different tire than the Ridge...  Unless you're driving 50/50 offroad/highway i would strongly discourage them.
The Terra is about 20% louder than factory Duratecs.  Compared to the Ridge, the rubber is harder, the tread pattern is more blocked with larger gaps, and they are much heavier..  this helps in off-road conditions at the cost of general driving dynamics and performance on pavement.
I have extensive expierence with the Terra and while it's a great tire, the Ridge blows it away in regards to street manners and performance.
If cost is the only thing holding you back, i would just make sure you know your going the opposite direction now in regards to road manners.  Again, forget about it being "e rated", that doesnt play play any role in how the tire will perform.
In my opinion, the Ridge is worth it's cost in gold.  Expensive trucks and tires are the biggest factor that will alter how your truck performs.
Edited by PabloK
    • Not sure about DFM tech but i know there's a stop/start deactivation button.
    • I could be interested if they axed cylinder deactivation and at least have a button for stop start. I’m sure the HP numbers will be higher. I would want a longer warranty to help build confidence. I’m a less is more guy as I get older. A V-8 work truck model would be my choice. I know a few outfitters for custom additions I prefer.
    • It's official. GMC pulled the covers off the next-gen 2027 Sierra 1500, and we got the first official look. Full breakdown here: https://www.gm-trucks.com/next-gen-2027-gmc-sierra-1500-v8-trim-changes/   The quick hits: SLE and SLT are dead. The new core retail trim is just called "Elevation". Two new V8s, a 5.7L and a 6.6L built with high-performance Corvette architecture roots. No horsepower or torque numbers yet. The 2.7 TurboMax finally ditches the old gearbox and gets the 10-speed automatic. AT4X moves to larger standard 35-inch tires with front and rear e-lockers, Multimatic DSSV dampers, and heavy-duty Jounce Control Dampers. Over 60 inches of combined display on Denali Ultimate and AT4X, complete with a motorized articulating center screen and an adaptive passenger screen. Seven simplified trims across the entire model line to clean up ordering confusion.   So let's get into it: New 5.7L and 6.6L gas V8s with custom active exhaust tuning and a Corvette connection. Is this the exact engine lineup half-ton traditionalists have been begging for? Purging the iconic SLE and SLT names after all these years to lean entirely on Elevation as the high-volume core. Bold move, or a mistake? That motorized articulating 16.3-inch screen that slides up to reveal a hidden dashboard vault. Awesome mechanical theater, or does it make you nervous about long-term durability? Physically lowering the headlamps in the front fascia to improve road courtesy and stop blinding oncoming traffic. Smart real-world engineering, or does it hurt the truck's aggressive stance? What trim are you putting your name down for on day one? Drop your first impressions below.
    • My overnight hospital stay turned into five.  I developed a post operative fever and an erratic  heart rate.  A blood clot in the lungs was the culprit.  This is apparently a common post surgical complication and easily remedied.   I was the youngest in a four bed ward and a Doctor with a Geriatric specialization was in charge of my care.  All of the nurses were good and some were outstanding at dealing with old people.  It was very evident that my age triggered a different level of care!  My advice to any senior going for a hospital stay is to have a trusted family member advocate visible.  If not, you will still be well cared for, but you may discover that your voice  isn't as strong as it once was!
    • $4.25 85 oct. in town, down 50 cents.
