6 speed failure
2 hours ago, Grumpy Bear said:
And it still made it to 115K?
Tough gearbox!
Imagine what a bit of TLC would have done.
Yup, probably double the life?  Flush em boys and keep the GDI's clean too!  Not a certainty but this will most likely not be you with attention to maintenance during your ownership.
200.00 bucks 50-60K ago on flush?  200.00 now turns into 1000.00's
  • Replies 46
Thanks for the info! I’m getting a VERY slight “chirp” sound on converter in and out of lock up. Is this a sigh of impending failure? If so, is it time for a new/rebuild? (Of course it’s just now out of warranty)!!!
@tlaw91 what state are you in? Definitely keep us up to date on all this stuff it's a big help to know what the dealers are doing with problems we encounter!
Awesome post! I also love to know what y'all techs see on a daily basis and some background info like you did on this one. I personally made sure to get my trans flushed at the dealer at the recommended mileage, like 97,500 or something like that. I plan on doing it again at 150k.
One question though, what is TECHM? is that another term / acronym for the valve body or computer in the trans?
Just say no to transmission flushes, even though some dealers push them.  Drain, change the filter, and refill is the only way to go.  Flushes, especially at extended mileages, may require a rebuild before long.
[mention=224859]tlaw91[/mention] what state are you in? Definitely keep us up to date on all this stuff it's a big help to know what the dealers are doing with problems we encounter!
Georgia- lots of hills and high mileage out here.
So you’re saying change the fluids.  I’m doing mine as soon as the weather breaks and I can start DDing my car.  What are the torque specs on the Transmission pan bolts?  Anything else I need to be aware of before tackling this project?
Interestingly enough, I have a slow, rhythmic noise coming from my converter that I can hear when the truck is idling. It sounds like someone is snapping their thumb.  It can slightly be heard from inside the cabin, but its more noticeable outside the truck. I asked one of my local dealers to take a look at it, but they couldn't hear it. I even took a stethoscope to the bell housing to verify it was the converter and that is where the noise is coming from. The sad thing is that my truck doesn't even have 20,000 miles on it.
Yep. I have too. Had it since new. There is some other talk about it on here as well. I guess it’s normal. I have 20k as well. No issues with trans.
Thanks for letting me know. That makes me feel reassured.
That sounds a lot like a vacuum pump. I mean you have perfectly described a vacuum pump noise.
You sure you aren’t hearing a vacuum pump?
-GM Tech
-GM Tech
I'm not sure. Could you explain it a little bit more?
Does the pump grinding into the case happen with the 8L90 when it has the factory Mobil 1 fluid that is hydroscopic?
My 8l90 shifts fine but I only have 10k miles on truck. My truck was built 12/2017 which means it has the older Mobil 1 fluid that is hydroscopic?
I haven't received any notice to have the fluid exchanged to the newer type. That is a TSB, and you have to prove your trans is shuddering correct?
    • 37's would probably fit with a 3" lift. GM only has two gear ratios for these trucks 3.73 for gas and 3.42 for diesel. And they can't be programmed for anything else at the moment. The rough country module just corrects the speedometer and odometer to adjust for tire size it's not a programming device.   You haven't said if your truck is gas or diesel, but for a gas truck the 10L1000 with 3.73 gears has a lower final drive ratio than the 6L90 it replaced would if it were swapped to 4.10s. GM used the same 3.73 gearing in 6 speed gas trucks. I don't think you'll have any issue running 37's with the 10 speed other than the reduction in mpg and towing/weight capacity which is as much of a function of the lift as the tire size.
    • Actually, it probably was the brakes.  It's weird the way the messages came across, but I took it to the dealer thinking that something was wrong with the sensor and in fact, the rear brakes were shot.  What I don't understand is why the messages never said, your brake pads are low.  First I got the message I posted above, taking about new pads being detected.  Then I got a message saying that the system needed repaired.  It never said, change your brake pads.
    • Did the KYBs keep it the same height in the front? I was concerned that pre-assembled assembly would raise it up an inch to standard non-z60 height.. I guess which it would make the rake 1 inch instead of 2 inches.
    • Thank you for keeping the train on the tracks and for a thoughtful engagement. I enjoyed the reflection on a previous stance to refine and improve your position. I like that inquisitive flexibility about you Atlas.    No the process isn't sterile. Hundreds, perhaps thousands of miles of piping, vessels, pumps. Chevron, the people I worked for, were keenly aware that there is a market for what is known as their "ISOCLEAN" line of lubricants. These are lubricants that are the same as those sold bulk that are further processed by filtration to a level your particular application demands. They will filter and package and provide lab documentation as required. Do not kid yourself. Every gallon of oil that goes into a Chevron Turbine, reciprocating compressor, generator is prefiltered and tested before being charged. Lest wise it was when I was there in the plants I worked in.    There are requirements set by manufactures for the cleanliness of the oils used in their equipment. OTR such as CUMMINS has standards shared with customers on this. Commercial interest selling to Ma and Pa do, but don't share that information. Not even upon request but internally, they do exist.    The GM study sited, (Graph from Machinery Lubrication in previous post) only shows "relative" importance.  I find that fascinating. By constructing the graph like this they admit there are dozens of factors in engine life and via scientific method determined the effect of 'relative cleanliness' on engine life not in miles but in 'FACTORS'. This allows a certain amount of reverse engineering does it not?   They even provided some touchstones. Beta 75 as a reference point. Wonderful stuff!!   Smaller blenders CAN and some DO take the time and effort to do better than a refinery or large bulk blender, like Warren Oil, in improving the "in the can" cleanliness. No I don't have a list but testing could generate that information.    Again, but one of several levers we can pull to improve engine life. The simplest is keeping a clean work station while doing your own oil changes.
