I mistakingly removed the nut on top of my front passenger side shock while installing MotoFab front leveling kit. I got everything back together but the shaft spins and I can’t grab it with anything due to it being sunk into frame. Any ideas on what to use to tighten this up?   I’ll try to snap a pic tomorrow.
Edited by danmc96
Typically, the tip of the shock is used to prevent it from rotating.  Some will have provision for an allen key (or something similar), some will have a machined in square or hex to put a wrench on the end.
Wait you removed the top strut bolt that holds the spring down? Did you remove it completely? If so you will need to pull the coil over out and use a spring compressor to re-secure the nut.
A vise grips with some rubber hose on the ends would work if you can get it to grab on to the shock piston through the coil spring. Then brap it down with an impact gun.
I have had good luck with the weight of the truck pushing down on it and the impact going to town.
If you are asking how to reassemble a completely apart strut and coil Then yes, you will need some spring compressors.
  • 8 months later...
whats the update on this issue? were you talking about the center nut on the strut?
I did the same thing while not paying attention awhile back.  I had to remove the coil and shock from the vehicle to repair it.
  • 3 years later...
Can you tell me how you got the spring out? The top of my strut snapped off and I've tried lowering the control arm as far as it'll go but I can't get pressure off it. I'm thinking my only option are the widow maker spring compressors if I can get them in there and cranked down. Looks like it might work but I'm not exactly rushing to try it lol. Any ideas or tips greatly appreciated!!
Edited by rahool82
With weight on the strut, you can wrap/lace the spring (the weight on it keeps it compressed some) with a heavy gauge wire. The more and tighter you get it laced the safer it will be. It should be enough to hold it all together to get it out of the truck. Unless you have a fancy strut compressor, then the dangerous part of getting the wire off while under tension. At least its not going to damage the truck and its not right in your face either.
Out of the truck you could take it to a shop too.
Edited by asilverblazer
Not a bad idea, might do this in addition to the screw down compressors, just for some extra pieces of mind. Thanks!
No fancy spring compressors here, just the old beater rentals from autozone
Edited by rahool82
Get it out of the truck then using the rent-a-compressor will be easier.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
