(Updated to reflect I have purchased BRAND NEW OEM LED Harnesses to accompany these lights)
For sale are my Chevrolet LED Tail Lights. I originally purchased these to replace my existing tail lights but had a change of heart and painted my existing housings instead. In great shape and will be cleaned and polished for new owner. Asking $440 ($470 shipped)
If you have any questions or want additional pictures, shoot me a message,
Edited by youn1033
Additional Parts
Are these still available?
i have a set like new w harness uncut for 530 shipped if interested 40be0b38ce1e411e9d523c7710eafe38.jpg20190701_224150.jpg20190701_224143.jpg
Still available and the harnesses can be purchased for around $130. If someone wants a harness with them that bad I'll be happy to buy it and sell it for $550 shipped all together.
