You guys are lucky. Its $150 ticket in edmonton for aftermarket or enlarged muffler tips. A tesla owner bolted a fart cannon on and got a ticket for it.
On 6/1/2021 at 10:29 AM, bdallas said:
100% incorrect??  Which part?
What is more likely to last longer, paint or a peelable removable rubber coating?
Which can handle higher temperatures, a paint rated for 1,200 degrees or a coating rated for 200 degrees?
My point was that if you're going to to through the trouble of doing it yourself, why not use a method that is going to give you the best chance of longevity.
You said it does not handle heat well and that is not true.  You apply it properly and it will do just fine on a truck and will last a very very long time, and still look great.  Like I said these tips are not going to generate the same heat as a corvette or a supercar so plasti dip is just fine.
Obviously powdercoat is the best, but that is a much higher cost that perhaps OP does not want to do.
If going DIY route, plasti dip is almost foolproof while painting them with high temp paint one better ensure they prep it properly or it will not last as long as even plasti dip
Tips pictured here are primarily stock oem tips ??
I had a mine powder coated the first weekend the truck was home.  Cost me $50.00.  If you have a factory trailer hitch installed the only way to access the 2 top bolts is to pull the steps.  Simple process but a pain.  The factory hitch takes up all the room underneath where you would slide you hand up to loosen the top bolts.  I really like how the blacked out look worked on the Red truck....
it really looks good how it matches your other badging!
however, just in case it helps someone else (unless the silverado is different in some way) it is possible to access those top bolts without removing the side steps. And actually I found getting those side steps off was a major pain! there are plastic clips that hold them on, likely so they will snap into place on the assembly line before the screws are installed, those clips bend back behind the bumper so they will not pull out. one of them is accessible with a pry tool, the other two are completely impossible to get to. I had to cut them off in order to get the step pocket off.
to access them without removing the pockets, you'll need a gear wrench, its quite possible to get a gear wrench on the bolt heads and remove them.
skip ahead to 3:30:
Hope this tip is useful for someone!
skip ahead to 3:30:
I did mine without removing the side steps because of the blind spot sensors. I used a 10 mm wrench like the one in the pictures and went 1/2 thread at a time.
It can be done but it's time consuming. And also done forget to paint the bolts clips because if you let them unpainted they will be visible on top of the black tips.
Good luck and watch out for your knuckles....hahaha.
I bent mine up slightly so they weren't visible anymore. I don't plan to put the stock tips back on, but they'd still be usable even if I did.
You can buy a ratcheting box wrench at Lowe's.  It's made by Craftsman.
Did you do a gloss black on those tips?
Edited by Diamond817
Yes, I went with gloss black and it turned out great.  Been on there a month and a half and still look great.
Maybe I am late to the party, but have others noticed that they look a lot like USB ports?
    DaleB
    DaleB
  • Who's Online   5 Members, 1 Anonymous, 1,530 Guests (See full list)
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
