Just bought 3500HD GMC Denali SRW and looking for some good mud flaps. I am leaving this truck stock and will be towing a boat. Tough to see how they will fit/look as a lot of the websites don't show them on the truck. Suggestions?
Pretty sure Rek Gen makes them for the SRW as well.  My post with pics on my DRW:
I just bought a set of Dura flaps
pretty pricey but they seem good and effective
I got the ones with the weights since I drive in the snow at times
I was going to go with OEM but they didn't look like they would do much
Any pics of the Duraflaps?  I am considering them but would like to see coverage and how they look.  I also don't feel like the OEM would be of much use.
    • I have 2 choices.
