On 7/25/2020 at 9:13 AM, lebag335 said:
I’m in Texas too. How does the state sticker affect the windshield tint. I’m concerned about removing old sticker and damaging the tint?
We use a clear vinyl static rectangle and stick the registration sticker to that then stick it to the windshield.  That way you can pull it off without damaging the film. We only do 80% clear UV film.
update, got 30 ceramic on front doors and 50 on windshield with no issues so far.
Update. I had my windshield tinted with Air80. Ended up with some bubbling around the rear view mirror so they redid it. No issues with the electronics either time. It definitely makes a big difference with the heat inside the truck.
Be careful tinting your windows!! Some will say nothing below the "AS1" Line, some say 4 inches some say 6 inches etc... What may be legal in your state may not be legal in another. By that I mean if it's legal in your state and you drive into another state "They CAN get you!!! Most states do not allow much other than factory tint on driver and passenger side windows but its OK to tint back and rear side windows completely black. I know of many folks whos tint had to be removed "ON-SITE" before being allowed to continue!!
This probably isn’t true.. if this were the case, you could get pulled over and ticketed for not having a front plate in states that require 2 plates.
By the way I am a former officer on a state level. All operators of motor vehicles must comply with vehicle requirements (Private or Commercial) in the state in which they are operating a vehicle. Plates and Window tint are separate issues!
This is totally true. If the police officer wants to enforce his state law on window tint. He has every right too. Most don’t because they see you have a different license plate. But they can. My sister lived in Nebraska. Drove over to Iowa and got pulled over for her tint because there front window laws are different.
You are correct when you say "Most Don't" BUT they can!!
On 7/21/2020 at 6:08 PM, birdsdawordxxx said:
Has anyone ran into any problems with getting their windshield tinted.
Cause being able to actually see is way over-rated.
  • 2 years later...
Has anyone actually had any issues?
I just picked up a 2023 LTZ and my tint shop who I've used for 8 years just told me this. I have to sign a waiver to get Air 80 put on my front windshield (they use Llumar.) He said they'd shove towels/etc down in there to be safe, but I will need to sign the waiver.
I have 35% ceramic 3M tint on the whole windshield of my 22 AT4. It has been like this for 6 months and I have had zero issues with visibility or the electronics in the truck. I had the same on my 21 AT4, also with zero issues. I have used the same tint guy for 10+ years and he does great work.
Zero issues.  Have the Air 70 on the windshield and 15% on the front, rear and sunroof.  I can see the HUD just fine.
As far as the inspection sticker, I ended up buying static cling stickers.  I cut it out a little bigger than the inspection sticker and then stuck it to the windshield.  Before attaching the inspection sticker to the static cling sticker, I put the adhesive side on a t-shirt so that it picks up lint.  After doing this a few times, I pressed it to the static cling sticker that is on the windshield.  Now I can peel it off with no issues and I don't have to use a scraper.  I also attached the toll stickers the same way.
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   0 Members, 0 Anonymous, 528 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
