Modern diesels are going through the emissions hell right now that the gassers went through in the 80's and now overcame, so I would say go with a tried and true gasser.  Diesels are having all kinds of issues trying to meet new diesel emission standards that costs thousands and you have no way of knowing how long a modern diesel will run healthy (lift pumps, DEF systems, etc).   I'd wait another 5-10 years before looking at a diesel unless you absolutely need one.
  • Thanks 1
2 hours ago, Dunn said:
i bought gas for those exact reasons.....i dont need a diesel just need payload, so why pay extra and have more maintenance.....it just didnt make sense
your not towing that much weight just barely over a 1500....any 2500 should tow that weight no problem
Yeah, also I am taking another trip in a couple weeks and I plan on running over a local out of service weigh station. If I am only 100-200 over payload and under the 15,000lbs GCVWR, which I sould be, I may just hold off anyways. The kids are only going to be going with us for 3-4 more years anyway. So if I am close it may be a mute point..
As stated above, the new diesels are hamstrung with the new emission BS, all of them, not just GM. If you like your 1500 with the 6.2, you're just a few mods away from it hauling that trailer a little better. But you're never going to get that planted, rock solid feel the heavier truck will provide while towing.
  • Thanks 1
Lots of positive reviews on the gasser 6.6 now, and don't discount a 6.0L
Until GM offers a 10spd for the 6.6 gas, I will never consider one for my personal vehicle.  I have two 2020 gasser work trucks for my business but my personal truck is a 2020 HC Duramax.,  The 6.6 gas is cheaper than the Duramax and gets the job done just fine but IMO they are not even close to being as pleasurable to drive as the Duramax.  Long drives towing with the gas, lots of shifting and high revs whereas the Duramax quietly hums along with power to spare.  Even if i didn't tow much I would prefer the diesel.   The additional maintenance costs are well worth it!  The 10spd in the Duramax is awesome, so don't forget about that benefit as well.
As far as the reliability, I have not had one issue with emissions on Duramax trucks and I've used them for plowing, short daily drives and everything in between.  Don't let the comments about reliability and all the emissions issues scare you away, they are very few and far between.  The Duramax/Allison also has a 100,000 mile power train warranty, gasser only 60k.
All that said, I would be very interested to drive the 6.6 gas with a 10spd transmission, I just can't understand why they wouldn't offer it. The GM HD gas motors are incredibly reliable, we have had some transmissions go on our gas work trucks but not one issue with the previous 6.0's and I'm assuming the 6.6's will be just as reliable.  Drive them both and decide for yourself..
I'm in the same boat, my trailer is a touch lighter though...  I would love the diesel but I can justify the extra $10k on top what I am already looking at to upgrade from a half ton.  Diesel on average is more expensive in the NE so that also plays a factor.
No 10 speed with the gasser because they want you to buy -  spend the money to buy a diesel.
The diesel power over gas as I said and CRApex mentioned.
Payload is higher on gas truck than diesel, mpg towing is probably as good as your 1500,  gas tank is 36 gallons, and it will pull the load you described easily. And yes its 10k cheaper.
I recently transitioned to my first diesel. It is so smooth and tows really well. But I think a large part of that is the 10 speed transmission. I have not had to deal with any issues yet, so we'll see how I feel in the future. But for now, I'm sold on diesel.
On 8/11/2020 at 7:22 PM, Londart2020 said:
Little late now. The truck towed the trailer like a mule team. Went up the hills in Idaho and Montana no issues 70-75mph. Its just the legality of being over the "payload" and the 24 gallon tank for long trips sucks.
How much over payload are you?  It seems from a legal standpoint you get 5% leeway. So in the case of my truck I can be like 300lbs over GVWR and still be legal.  I’m only 80lbs over, so I’m going to try to make it work until 2022.  It’s getting harder to wait though. Putting bikes and kayaks in the camper instead of the truck is going to get old really fast.  I want a HD truck with 8 foot bed, fiberglass cap, and roof rack for the yaks.
Well I had never heard this, and have not weighed it. Its also kind of a mute point now too..took delivery of this friday.
  • Like 3
  • Thanks 1
Congrats man. Did they cancel your order?
  • Thanks 1
Gorgeous truck. You'll love that diesel.
  • Thanks 1
Thank you. Yes, I was told they had too many orders and not enough parts, so it came down to checking local dealers everyday to find one in stock.
Wow... well at least you found one.
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
