On 10/7/2020 at 4:40 PM, Bob2C said:
Would an engine flush say like an amsoil product every few oil changes be a good thing to do to prevent any buildup?
It wouldn't hurt anything.  Depending on what oil you use and how often you change it as well as driving conditions.  Some don't realize that if you drive very short distances and don't really get the engine up to operating temperature, it can cause more problems.  With these new engines and 8qt stumps. It takes way longer for the oil to reach optimum temp.
Using AMSOIL's engine flush is a safe way to keep things clean inside at oil change time.  It helps to put all contaminates into suspension and they drain out when you pull the drain plug.
The best thing is to run a quality oil and filter and if you do extended oil drains get a used oil analysis to see how things are inside the engine.
Thanks. Had oil analysis done recently on amsoil xl @6k. The prior was gas truck at 3k. I can easily say amsoil xl can go 9k miles with out problem. Gas truck I would do about 5k max IMO
Nice report.  The only issue I see is fuel dilution. Blackstone tests for fuel on an old system and isn't very accurate.  This is also why your flashpoint is so low. You more than likely have a higher fuel dilution than what is showing.  DI engines are bad for FD.  This is also the main reason I feel that GM when with an 8qt sump.  If they stayed with a 6qt then you couldn't go very long on an oil change since the oil would be shot due to fuel.  It isn't the oils fault.  As you can see AMSOIL did a great job protecting even with high fuels.  Another reason to use a high quality lubricant like AMSOIL.
I do a lot of idling and town driving. I’m sure that has a lot to do with it. My other DI engines are the same way.
I think my biggest problem with amsoil isn't that it is bad as it is quite good (best is debatable) but the fact that amsoil sellers/fans are like cross fitters, they just hound you with their information, findings and pages waving flags, posting their boxes full of it and talking how it is the best by far or you will have a higher chance of a failure. You search for amsoil info and you get 300 pages from amsoil forums and dealers/sellers with their information and test results they want you to see and it supports their agenda. Then you have the people selling it giving you their information, well of course they want to you buy it so they get paid. It just feels like it is borderline propaganda with how much they try and force it down peoples throats, and it is that feeling that has me turned off by them. I have never seen any of the other brands pushing their oils on forums, maybe it is because amsoil is small and trying to carve out a niche or following in the market place? Then you factor in the high cost and that the other top main stream brands (Mobil, Pennzoil, Shell, etc) are tested for millions of miles in the engines by designers and engineers of factory motors like GM's LT/LS motors, Dodges Hellcat/SRT motors and even McLaren's and their 720s. They are the same brands used by top race teams in Formula 1, Nascar and Top Fuel, granted in many cases they are special weights or blends but they get to pick and choose oil brands. If all that is good enough those people then my truck/GTO, which was benchmarked with Mobil, it is plenty good enough as well especially as I prefer to follow a reasonable oil change interval of around 6k. Fresher top tier but maybe a half rung down oil from Mobil at a nearly a 3rd the price is better than top tier 3x the price amosil at nearly 20k intervals. And no, the engine isn't going to fail at 75k, 120k and so on most likely because I don't use amsoil and amsoil isn't going to miraculously guarantee no engine issues to 300k+, it is a mechanical unit if it is going to break it can and will break. I keep my vehicles to 150-200k without amsoil and will continue to do so as that is what is recommended by those who built and torcher tested the motor.
Tyler
So if I get you right. So get turned off from people like me who sell and use Amsoil and give testimony’s of their use. In my case hundreds of costumers over 30 plus years. But you’re ok with big oil paying for endorsements like NASCAR drivers, formula one and NHRA. Got it.
amxguy1970
I agree with your comments. Have used dino oil for years, went to full syn. 3 k OCI's.
The Amsoil hype got me to.
But I switched to Amsoil ATV oil for my Honda and the difference in motor quietness and transmission shifts was very noticeable.
OK OK OK. Enough Amsoil sales stuff on this AMF thread! Go start an AMSOIL thread.....
amxguy1970
We had tractors we added hydraulic systems to power our clearing attachments. They were high pressure and flow pumps. If you had a high pressure hose failure it would take out the pump through cavitation ( loss of oil). There’re basically like automatic transmission. Amsoil synthetic hydrolic oil gave enough lubrication to allow shut down without losing the hydraulic pump. My father had an 88 Ford diesels with a c-6 transmission. He pulled a large 5th wheel. He also pulled our tractors when needed. At 100K the C-6 fried. With the rebuild we added Amsoil transmission fluid. We also add a bank’s turbo kit and gear vendors. The C-6 and 410 gear made 74 mph the top speed. Gear vendor gave it 94 mph. With Amsoil transmission fluid and oil. The truck never had another failure after an additional 180K miles. I have many examples like that. We sold over 200 of those model tractors with Amsoil fluids in them. Remember we make money repairing the equipment we sell. Amsoil reduce those hydraulic repairs. Of course there was always people who would put in Dino hydraulic fluid. After I told you so, we’d repair them after they burn up the drive pump. The transmission and hydraulic pumps savings made me a Amsoil motor oil user.
  • Like 3
Rather than saying non helpful things, Listen and learn something, Oil is the #1 contributor to AFM failure hence the reason for bringing up high quality products that help stop the chance of AFM problems.
amxguy1970
That’s cause Amsoil isn’t hype, it really is a superior product [emoji6]
So using Amsoil will prevent AFM failure, got it. Can this be put in writing from Amsoil?  If so I am sure their sales would increase drastically.
Really simple to me. A 100% synthetic motor oil, gear lube ECT. has to be superior. Is it necessary? No!
Tyler
With all due respect, the oil companies you’ve mentioned are NOT picked by automotive manufacturers because of their outstanding qualities, they paid the automotive manufacturers for it and meet “MINIMUM” requirements in order to keep their engines running through the manufacturers warranty period.
You don’t like hearing about the superior Amsoil oil, why? No one is making you buy it, rather than ignoring it you’ve chosen to interact and make your own claims on your cheap minimum requirement oil which great, that’s what you use then that’s what you use but don’t think for a moment that you or anyone else gets a pat on the back for feeding your vehicle the cheapest, minimum required oil and then later blame the manufacturers for failures.
It’s like eating foods containing MSG all the time, they’re all low quality, cheap costing food and eventually the lack of nutrition which would have helped maintain a healthy immune system will cause system breakdowns. Well, same goes with everything in life, engines are no different and being proactive only helps.
Good luck [emoji1303]
Absolutely correct, not necessarily required but highly recommended for longevity [emoji6]
Still boggles my mind, folks buying $50K plus vehicles only to complain about spending a few extra dollars helping to protect what’s already a depreciating asset, why not help it last, eventually with most pay it off and keep it, far cheaper than starting a new financial commitment, help it last.
My AC guy uses Amsoil in his two trucks, one has over 300k miles on it and the other one has close to 200k miles with never having any engine problems but did say he wishes he could’ve said the same for the rest of his truck lol.
Hey, what’s cheaper, paying a few dollars extra on OCI’s for Preventative maintenance or engine repairs? Only you know the answer to this.....
Gooooood luck to everyone and God Bless
    d.lowrey
    d.lowrey
  • Who's Online   6 Members, 0 Anonymous, 2,469 Guests (See full list)
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
    • Fix one problem and find another.   Truck didn't have a thermostat in it so I flushed out the system today and refilled with 50/50 Dexcool. This truck is so old (LOL) that it has a sticker under the hood alerting people to the fact that it contains such. There is also an orange supplement with the owner's manual alerting the owner that "Your vehicle is one of a number of late production 1995 General Motors vehicles that use a newly developed engine coolant in the cooling system..."   I was still a little flummoxed by what seemed like a rich condition (exhaust smell, and a puff of carbon with a punchy rev). While watching the coolant temperature and testing the thermostat with my scanner, I happened to notice the IAT (incoming air temperature) to the intake was -40F. I know the temp is below average today, but I can still feel my face, and I was wearing shorts.   D'oh!! I realized I had never plugged the IAT back in, and the airbox was out while I was doing coolant. So I paused, reinstalled the airbox and plugged in the IAT, and viola. Things cleared right up, and I watched the coolant temp climb to a reported 198 degrees on the scanner (195 thermostat) and then it dropped to 194 (open) and then back up to 198 and held. Let it cool, came back, checked the coolant level and was satisifed.   Victory lap?   It needed more than the couple of gallons of gas I put in it from almost bone dry, so I ran it up to the gas station. It had earned it, or, at least I was pretty certain I wouldn't be draining or removing the tank anytime soon.   CEL popped on just as I was cruising a nice steady 40mph, just after coasting down a slight downhill curve.. Of course, it did, because, why let me enjoy not having dash emojis for a little while.   I just happened to have the scanner plugged in. I don't text and drive but I might scan and drive. Don't tell the police.   P0401, EGR flow insufficient.    Well, hello, EGR... ...my old friend! Welcome to the party, now that the engine reaches the factory-programmed operating temperature. I'm sure it was gagging on hostile, rich exhaust and carbon this whole time so I'll take it off and look again.   At least it's easily accessible, and worst case, about $65 to replace.   To keep, or to sell... Hmm. I want it running correctly either way. It's easier to sell when there are no fault codes.   It needs tires (they're aged out and cracking)   It could probably use an oil pan seal, or maybe the timing cover gasket/ junction with the pan needs redone because I've got an issue there that leaves a drop of oil on the floor.   If I do tires I'm sure they'll say the ball joints could use freshening, and, and, and, and.... At some point I'll have to stop. I can't (shouldn't) make it perfect, that's not what this rig is.
    • Take it back. That's about all you can do.  Mark
