Good morning All!
Looking for some help for my son's 2012 Silverado, 4WD, 5.3L. I have attached a video of a pretty bad oil leak my son has on hi truck. Video is BEFORE any repairs were attempted.
1. Son thought it was the oil pan gasket, so he went through the process of removing front differential, and other parts to perform repair. Halfway through disassembly he realized it was NOT the oil pan.
2. He then thought it was the rear main oil seal, so he put truck back together, and had it towed to my house. I spent the last 3 weekends figuring out howto, and then replacing the rear main cover/seal.
3. Started truck and still $%%& leaking!
Son shared this video with me, and I viewed it several times now, and based on what I saw under the truck and the video, this looks like the oil pressure sender, or something up higher. It is clear to me now that we worked on the wrong thing!
I am about ready to pull all the remaining hair out my head on this, and was hoping someone could view the video and give their thoughts?
Is it the pressure sending unit, or possibly a valve cover (I doubt this, but possible), or intake gasket?
It is now below freezing in Michigan, and I do not have this truck in the garage (I WAS in the middle of my rebuild on my 1985 Camaro, so I have no room, and need to get this truck fixed, or towed to a shop if it out of my abilities).
I'd look into pressure sending unit. Looks like it is from up high.
Edited by txab
I got a response from you - txab via email, but it doesn't show up here - you asked if I checked the oil cooler attachment at the block - where doe the oil cooler lines connect to the block?
I have to get back under there, but I was assuming they are attached somewhere near the oil filter housing, and the leak is not coming from that are.
Appreciate the responses txab!
Those two lines that the oil is running around is what I thought was oil cooler lines until after viewing this on a different device, noticed I was seeing the trams cooler lines apparently. The engine oil cooler lines attach near the oil filter location. Your oil is running from up high, imo
Common item is a failed pressure sensor. This is a leak under pressure, imo.    Intake is dry on these engines. No oil/water
I'm not familiar enough with this generation engine to know the locations of cam and crank sensors, but those can be other leak locations
Edited by txab
I have this little inspection camera with a small display - gonna try to view the pressure switch with this, and hopefully this is the culprit! I will post an update either way, once I get this figured out.
If you change the sensor there is a screen beneath it that needs to be changed as well
Are we 100% sure that's engine oil and not trans fluid?  The only possible things that could leak that much oil back by the Bell housing are the oil pressure sending unit and the cam position sensor.  I think the 12 still has the cam position sensor next to the oil sending unit.  Pull the intake manifold so you can get a good look back there.
Mike - Yes, 100% certain that is engine oil.
So...last night, I tried to use the "My Lizard Cam" to see back there where the oil pressure sensor is located, and observe while running. Like txab said, I am certain this is a leak under pressure, as it did not start leaking immediately upon start-up, but soon after.
It is very oily back there, but could not see the steady stream I was seeing under the truck. Also, was able to squeeze my hand back there, and wiped all around the base of the oil pressure sensor, and it is actually dry there...there is oily buildup on that surface just below the sensor on the back of the block...where it bolts to the transmission.
With the fact that I now know that intake is dry, I am going to follow Mike's advice, and take the upper intake manifold off, to hopefully see better. It now seems to point to the cam sensor.
I want to try to uv dye in the oil before tearing into again, in the hopes of helping point out the source. Anyone had any luck with a particular brand/kit?
(I tried this years ago, and maybe it was inexperience back then, but I do not recall being able to see the uv dye using the "special" glasses and light. Maybe it was the product I was using)
In any event, Thanks Gentlemen for the advice on this. I will continue to post updates, as this has been a learning experience, and have no problem sharing the solution.
SOLVED: Update to this issue - Valley pan cover was the culprit!
All the "You-Tube sleuthing" watching the various videos on this topic did help a lot, but caused a lot of confusion, until I went to the GM OEM information. The RPO code is LC9, so I obtained the exploded parts diagram, and found that this engine has cylinder deactivation solenoids under the valley cover, and NOT knock sensors on the top of the valley cover.
Had my son order oil pressure sensor, filter, cam sensor, intake gasket, and valve cover gaskets from RockAuto.com. Parts arrived in 2 days!
Removed the intake manifold, and found the root cause almost immediately! OF the 11 bolts holding the valley pan cover in place, 8 were finger loose! Also, no evidence of any threadlocker ever being on the bolt threads.
Also, there was no cam sensor next to the oil pressure sensor; there was the connector for the cylinder deactivation solenoids only.
Everything was cleaned up nice, and as an added measure, I added a very light film of RTV to the Valley pan mounting area and the valve cover mounting areas, just to give a little hold for the gaskets. OEM instructions say not to, but after following the OEM directions on my transmission pan gasket, this was the way to go. Not good gobs, or even a small bead - just used my fingertip to lightly coat the sealing area. Also, used high strength removable threadlocker (Permatex - orange bottle) on the valley pan cover bolts.
I installed the intake manifold gasket dry, as the OEM recommended.
Started teardown and completed repair on Saturday, thanks to the RockAuto parts arriving one hour after I had cleaned everything up from teardown. Also, did this in 35 degree weather in my driveway.
Truck now has no leaks!
I think all the oil leakage contaminated the MAF sensor (intake had oil in it near the throttle body), and he had a bad oxygen sensor - Got a check Engine light on start-up.
Replaced both, and truck running good as new.
Hopefully, this information will help somebody else out, as I have spent about 6 - 7 weeks working on this truck (in between working and day-to-day life), and was ready to call an audible, lol!
One last note - when we did the rear main seal repair, we found several of the 12 mounting bolts for that cover were finger loose as well. We used threadlocker here as well.
Glad you got it fixed.  I have to admit, that's the first I've heard of loose bolts like that.  Might be worth re-torquing the rest of the engine bolts as well like the front cover, pan and maybe exhaust as well.
I am working on a similar but different issue.
Where does one access the 'GM OEM info' you referenced here:
Quote
At a site like alldatadiy.com for an online subscription to the info, or helminc.com/amazon/ebay for paper versions (if available).
Takes a little bit of time for them to be available, so if you have a brand new truck, I don't believe it is available yet, you should contact them first before subscribing to make sure it's available.
Jibe - I work for GM, so I have access to all the Service Manual information for ALL years. There are lots of exploded parts diagrams, listed by RPO code, so once I found the RPO code sticker in my son's truck, it was clear what I was working with.
If you need something particular, I should be able to help you out.
FYI the cam sensor on the gen lV motors are on the timing chain cover. Gen 3 99-06 and 07 classic is at the top back by the oil pressure sensor.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
