I will do my own oil changes and maintenance until no longer able to.
I already can not in the winter and I don't think the cow will let me milk her just 6 months of the year.
Kidding aside; I don't let dealers do anything but unavoidable recalls. I have a trusted and groomed local shop who satisfies my requirements for competence, talent and cost. They are getting harder to find too. Hold on to the ones you can find.
https://www.consumer.ftc.gov/articles/0138-auto-warranties-routine-maintenance
Quote
Do I have to use the dealer for repairs and maintenance to keep my warranty in effect?
No. An independent mechanic, a retail chain shop, or even you yourself can do routine maintenance and repairs on your vehicle. In fact, the Magnuson-Moss Warranty Act, which is enforced by the FTC, makes it illegal for manufacturers or dealers to claim that your warranty is void or to deny coverage under your warranty simply because someone other than the dealer did the work. The manufacturer or dealer can, however, require consumers to use select repair facilities if the repair services are provided to consumers free of charge under the warranty.
That said, there may be certain situations where a repair may not be covered. For example, if you or your mechanic replaced a belt improperly and your engine is damaged as a result, your manufacturer or dealer may deny responsibility for fixing the engine under the warranty. However, according to the FTC, the manufacturer or dealer must be able to demonstrate that it was the improper belt replacement — rather than some other defect — that caused the damage to your engine. The warranty would still be in effect for other parts of your car.
Will using 'aftermarket' or recycled parts void my warranty?
No. An 'aftermarket' part is a part made by a company other than the vehicle manufacturer or the original equipment manufacturer. A 'recycled' part is a part that was made for and installed in a new vehicle by the manufacturer or the original equipment manufacturer, and later removed from the vehicle and made available for resale or reuse. Simply using an aftermarket or recycled part does not void your warranty. The Magnuson-Moss Warranty Act makes it illegal for companies to void your warranty or deny coverage under the warranty simply because you used an aftermarket or recycled part. The manufacturer or dealer can, however, require consumers to use select parts if those parts are provided to consumers free of charge under the warranty.
Still, if it turns out that the aftermarket or recycled part was itself defective or wasn't installed correctly, and it causes damage to another part that is covered under the warranty, the manufacturer or dealer has the right to deny coverage for that part and charge you for any repairs. The FTC says the manufacturer or dealer must show that the aftermarket or recycled part caused the need for repairs before denying warranty coverage.
Edited by elcamino
I do my own, unless under lease maintenance.
Too many people rushing and not doing a diligent job.
Well said by many others.
Bottomline, sloppy maintenance might lead to a failure that’s your problem, sludge, or overfilling...
It's $80 at my dealer for an 8-qt. oil change and tire rotation. It costs me about $50 for the oil and filter. I don't have the equipment to easily do the tire rotation. It's worth the extra $30 to me to let the dealer do it. For that $30, my tires get rotated, I don't make a mess in my garage and I don't have to deal with the used oil.
Ridiculous.
I change my own for $40.
Mobil 1 0w20 12 qt box,
(oil is in a bag inside a box like a wine box),
at walmart is $49. Ac delco filters are $7.
I get 24 qts ( two boxes) of oil and 3 filters for around $120 = $40 . At this price I change it every 3500-4000 miles. Both of my 2018 5.3's.
I wouldn't let the dealer touch my trucks for an oil change. The last time they spilled oil all over, dirty hand prints and it wasn't full. 1/2 qt low when I got home.
They must have spilled the rest.
They let the car clean up kids do oil changes. No thanks.
Sent from my Pixel 3 using Tapatalk
1 hour ago, dieselfan1 said:
Ridiculous.
Actually they threw it away! I get my bottles back and found that they leave about 2 ounces per quart for quarts and four to five ounces per gallon jug in the containers. The dump the containers so fast......you get the idea......
4 hours ago, elcamino said:
You can claim this all you want but the minute something does go wrong with your vehicle GM will ask you or the dealer where it has been serviced at and if it’s not a GM certified mechanic good luck having them warranty anything.  Like I said, GM has WAY more money then you do!
For the $20 to $30 difference. I’ll let them pick up my truck do it, deliver it back, and when something breaks, guess what, the records show they have done all the maintenance on the vehicle.
As for someone else commenting on being lazy or too fat. I’m far from that, I love tinkering with my truck. Heck my father has a shop, but when the truck is under GM Warranty, you best believe I’ll let the certified guys handle it till it’s up.
Dealers have bulk oil tanks. Unless you are bringing them your own oil (who does that?), they aren’t pouring it out of quart bottles all day and leaving a few drops in each one. Imagine the waste.
You'd think an oil change and tire rotation is brain surgery......I can get an oil change done in 20 minutes dragging ass and the rotation done in another 20 with a floor jack and jackstand.  If you don't have an hour of time available in your life, you should reconsider how you're living.
Fear mongering.
  • Thanks 1
Its a 2 beer job - and who doesnt like day drinkin? Rotella gas truck had a rebate ending up at $9 per 5qt - thats good oil for a hell of a price though normally decent synthetic oil is around $20 per 5g. 50 bones is about standard these days with a free change every 4 changes due to the 2 qts left over after each change...
Sent from my SM-G975U using Tapatalk
I'd hate to think of how many quarts of oil I've poured doing them myself for over 35 years.  Of course now I've got 3 Chevy's and a Pilot to do, not to mention Quad, ZTR, outboard, tiller, log splitter... holy crap.  If a good coupon shows up I will allow the dealer to do the wifes' Pilot.  I will get my freebie and then do them myself.  I recently started using the Rotella myself, buy 5.3 filters by the 6pk.  I bottle the old and take it to the local tech who burns it in his shop HVAC.
6 hours ago, dieselfan1 said:
Ridiculous.
That is why I built this.  Out of all the oil changes I do I get a couple of qts every month from what drains out of the bottles after an oil change.  I use it in lawn equipment or when I get an old beater that uses oil every 1000 miles.  I can add more to it to hold as many qts or jugs as needed.  I just stopped at 5..  What I do is let the qts sit  on their side over night then dump them on here.  That way the oil is on the side and then drains right out and not trying to drip from the bottom of the container.
  • Like 3
    tararebecca
    tararebecca
  • Who's Online   1 Member, 0 Anonymous, 586 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
