On 8/24/2021 at 3:58 PM, Joe Brooks said:
Has anyone has the “shim” installed on the cam shaft position sensor long enough to know if that fixed the issue?
I just had mine shimmed. Had a no start 2 days later and now the thing also reeks like coolant. Today they tried the ECM re-flash. Will have to wait and see if that does anything.
Edited by Jessie D
On 10/5/2021 at 12:57 AM, Hello32 said:
I picked up my truck. Got their once service closed so didn’t get a chance to speak to the advisor. Receipt says reprogram ecm that was released on 10/04/21 and perform setup. One thing i noticed right away was the truck cranks for longer now. It makes you feel like your going to have an extended crank but starts up.
Yes I noticed that too. It seems to go for an extra second or so now.
Truck now has 5200 miles with 4 crank/no start episodes. Going next Friday for oil change and the ECM flash. Will update afterwards.
My dealer thought it was one of the relays so they replaced it. Unsurprisingly, I had a no start recently.
I just got the ECM update today. Any potential issues with premature wear with the longer crank time?
Wow, this thread blew up since I looked here last.  Dropped off my 21' Sierra AT4 3.0 Duramax for its third trip to the dealer for the Crank / No Start.  I've already had the ECM reprogrammed and the issue has even happened to the Service Tech during the second visit while they had equipment hooked up to it, they saw some sort of steering column / ignition code.  They reprogrammed the ECM again.  Still happening.  I've given them plenty to look into from what I've learned on this thread so thanks for all the info.
One thing my Service Rep pointed out today is that in order for them to continue with any work I'm responsible for the $185 in labor costs for them to remove the aftermarket theft deterrent system (wiring / connectors) that was installed at the original dealership that I had purchased the truck from.  Long story for a different thread...  🙃
I'll report back with details once I have them.
'I just got the ECM update today. Any potential issues with premature wear with the longer crank time?"
My brain actually hurts this question is so stupid
Edited by youcantkeepup!
I almost took your troll bait but then me and everyone else on here would have to listen to you spout off your bs resume and self fluffing. Keep this topic informative.
Sorry but.......
Here's informative for you. The more something is used, the faster it wears out.
LOL “youcantkeepup!” doesn’t need to fluff himself, you do it for him. Maybe someone who isn’t the second do-it-himselfer can chime in with meaningful information.
One bit of misinformation that my saleman had been told by the service department, is that the auto restart system does not cause wear on the engine starter.   I think this bit of 'folklore' comes from the fact that hybrid cars use the big electic motor to restart the gas engine.   If you notice when riding or driving a hybrid the starting of the gas engine is almost undetectable since it is so smooth a transition.   Our truck use an old fashion starter to start.   It and the flywheel gear, bendix and starter gear teeth all wear incrementally with each start.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
