6 hours ago, Craigpee said:
Great information! I added the wire from harnessdr and everything is working except my phone button. Is anyone else having that issue?
The phone button on mine only works if a calls coming in and u answer or want to hang up. Although I can push the wheel button and the phone won't  come on otherwise.
In the video he mentions the "Speak button and hang up button" works. What happens when you hit the speak button in the normal state? Can you actually give voice commands to call someone or is it solely to answer calls when they are coming in.
So I have a 2021 Trail Boss custom and am looking to upgrade the steering wheel so I can get the volume and talk controls.  Can someone list off all the parts needed?  I’m a little confused after going through every post so if someone can provide a summary in one post that would be awesome. Also if there is a video showing a step by step at all that would be awesome too. I watched the video tied to this thread but it didn’t necessarily do a whole lot in terms of showing how to do it.  Thanks in advance!
So I can confirm this works on a 2019 as well. Got it all set up on the weekend everything works.
I bought a junkyard steering wheel, clockspring(although I don’t think I needed it), Denali cluster from WAMS, and wire from harnessdr.
Both WAMS and harnessdr are the definition of customer service and care. They were fantastic and answered every question I had.
  • 4 weeks later...
So awesome! We love doing the Denali units with the Chevrolet startup and truck graphics just a cool combo!
  • 4 weeks later...
On a 21 custom Trailboss.  Primary objective is to gain audio control buttons on back of steering wheel.  I have installed the harnessdr wire and replaced the steering wheel to one with buttons. The rear audio controls still don't work.  Does the WAMS upgraded cluster allow the audio control function? Thanks!
Yes. You have to upgrade the cluster to get audio controls and the WAMS unit does this for you.
Would one of you IOR equipped folks please take a picture of your radio module? Should be located on the passenger side up under the dash closest to the passenger fender. This would REALLY help us out; thanks!
I think this is the radio module.  Do you need clear image of anything specific?
6 minutes ago, Chad Sommer said:
Ok that confirms what the service manual says thank you so much this helps with some other stuff we are screwing around with :) Thank you @Chad Sommer!!
  • 3 weeks later...
If you have been waiting to order a 20/21 High Country Gas US Spec cluster we have a few spares from the giant batch that we just got in this afternoon (that took nearly 6 months to get). If you want one order please order NOW. When these are gone they are back to backorder :( This chip crisis has been crazy with these units.
https://www.whiteautoandmedia.com/product/denali-high-country-cluster-upgrade-t1/
Edited by GTPprix
Just installed my High Country cluster from  WAMS & wheel it works fantastic. It made the IOR perform better but an upgrade would be a big deal
  • 3 weeks later...
A few people have expressed interest in a lower cost method to do this upgrade. While I think if you're going to go through all of this the real upgrade is the Denali / High Country variants we have come up with a more economical solution as well if thats the route you want to go :)
https://www.whiteautoandmedia.com/product/2019-2022-t1-ior-cluster-upgrade/
  • Like 3
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
