If it is just due to low resistance, then I would add LED hyperflash resistors to the left and right brake/turn signal lights, and if that doesn't work, perhaps the parking iights as well.
If you keep it, i would just add 4 ball joints, an idler arm and most likely pitman arm to you future list. My 95 s10 zr2 ate 5 sets of ball joints, 4 idler arms and 3 pitman arms in a 100k of use, a glaring weak spot even with the non zr2 variants.
Thanks. I saw that also, but wondered if Rockauto just was not selling the factory trans cooler. So, I have looked at a bunch of suburban radiator installations one YouTube and none mention an external factory trans cooler. Evidently the max towing package cools both engine oil and trans fluid through a HD radiator.
I’d be careful about treating any AFM/DFM disabler as a lifter-failure guarantee. It can change cylinder-deactivation behavior, but it is not a mechanical repair and it does not remove the collapsible lifters from the engine.
The other big thing is year/platform. A 2021 truck, a 2023 truck, and a 2025 truck should not automatically be grouped together for plug-in fitment. Exact year, engine, transmission, and refresh status matter.
Wire Pinout and Colors
Pin A: Brown/White - 5V Reference Signal
Pin B: Black/White - Sensor Ground
Pin C: Dark Blue - EGR Position Signal
Pin D: Pink/Black - 12V Ignition Power
Pin E: White (or varies) - Ground Control for EGR Solenoid [1, 2]
Understanding the Wires
5V Reference: A low-power current sent by the Powertrain Control Module (PCM - the car's computer) to the EGR.
Position Signal: Tells the PCM exactly how far open or closed the valve is.
Ground Control: The PCM completes the circuit to actually open and close the EGR valve using this wire. [1, 2, 3, 4]
This is what AI is telling me, in absence of access to a complete service manual for the truck. So there are two grounds and I think I determined one of them is bad. I need to run through the test sequence again to validate what I think might be a bad ground.
I'll be honest, electrical isn't my strong suit, but I'm learning.
Register a new accountSign in
