Found this TSB released last month stating there is a factory offered "fix" for those who want to do away with the idle time-out.
#21-NA-228: Full Size Trucks Idle Time-out Disable - (Oct 21, 2021)
Involved Region or Country
United State, Canada, Mexico, Middle East, Israel, Palestine
Additional Options (RPOs)
BTM
Condition
Some customers may comment that currently if the vehicle is left parked and running with the RKE transmitter outside the vehicle, it will continue to run for up to half an hour. If the vehicle is left parked and running with the RKE transmitter inside the vehicle, it will continue to run for up to an hour.
Cause
This condition may be caused by GM PEPS vehicles were designed with an idle time-out.
Correction
In certain situations, the customer will request that this feature be turned off because they need to extend their idle time. A calibration is available to eliminate the idle time out feature. If this calibration is installed, the dealer will need to print the Owner’s Agreement Statement attached in this bulletin and put it with the Owner’s Manual. This is a customer pay repair. The vehicle owner is responsible to be aware of any local ordinances that restrict prolong idling.
Important: The following needs to be a separate page in the bulletin and the dealer will have to print it out and place it in the glove compartment or Owner's Manual.
When the vehicle was produced, it came with the auto-shutdown feature enabled. If you are not the primary owner of your vehicle, please note that this feature may have been disabled by a previous owner. The vehicle owner is responsible for being aware of and complying with any local ordinances that may restrict prolonged idling. The vehicle owner can have this feature re-enabled at owner cost at any GM service center.
  • Like 4
BTM
Condition
Cause
Correction
 Thank you for posting this!!!
Interesting. I didn't catch that "feature" in the owners manual, but there it is, "Extended Parking" with the timeouts listed. Good to know. I'm fairly certain I hate RKE/rfid fob stuff now. Gimme a dang key, and if I start the vehicle, I intend to leave it running until I shut it off! That's been the worst feature of this new truck.
I can see both sides on this.  It would be nice if it was owner selected (I.e. free).
I had an Impala with push button start.  I took a family member to the hospital.  Dropped off at ER and then went to park my car.  In my hurry to get back in the hospital, I did not shut off my car properly.  I did notice that when I hit the button to lock the doors that I didn’t get the right “beep” but I didn’t realize that meant the car was still running and, like I said, I wasn’t fully in my right mind.  Well, after 6 hours in the hospital, I came out to my car running.  I guess they didn’t have that feature back then (2015).  I think the option is well intended, but it shouldn’t cost money to knowingly override it.
Def going to be looking into this ASAP. I go direct to calls from time to time at my fire department and being able to not have to worry about the truck shutting off while on the side of the road which in turn kicks off my lights, would be great. Plus on those cold days, truck stays warm while we are out.
Thank you so much for sharing this! I had to pay $255.00 for this here in Canada but now my long distance remote start will keep the truck running up to 45 minutes. Why so long some may ask? Well is is below -30c here this week and 15 minutes doesn’t even get the motor warm let alone the interior. And the factory remote is good for about 200 feet. In hind sight for what I paid for the remote start  I could have subscribed to onstar for about 5 years but I hate monthly payments. Will definitely think about it for the next one but for now I am very happy. Now to just find a way to disable stabilicrap……..
I friend was telling me a similar story with her elderly (80's) aunt and push button start.  She had went grocery shopping and when she came home she was tired so she called her niece who lives a block away. Mary was saying she went right over to help Nancy unload the groceries. Upon entering the garage she found the car was still running, some 10-20 min after she arrived home. Nancy being hard of hearing did not hear the horn honk when she left the vehicle.  I am not sure if the new 2021 Jeep SUV's have the time out feature but it could have been a real catastrophe had the engine continued to run killing anyone in the home with carbon monoxide.  I hate the push button start.. I recall my dads first car had push button start, a 1950 Chevrolet but they still had a key. We have come full circle now everyone thinks that new technology.  LOL
A little button for extended idle time and turning off cylinder deactivation would be helpful. I’ve been in vehicles with a button for tuning off stop start. So what’s the deal?
So i had this TSB completed on my truck last Monday...much to my disappointment, it didn't work. I reached on one of the FB groups, and someone posted this TSB that they said worked. I'm going to contact my dealer and see if they can give this one a try. Just as a heads up for anyone else looking to do this.
Morning all...I had the dealer do the above TSB(21-NA-056) and I can confirm it worked. I did have to pay for the program from GM and apparently GM Tech gave the dealer somewhat of a hard time about getting it but they were able to get GM to give it to them. Just thought i'd give an update for anyone debating on doing this.
59 minutes ago, AJMBLAZER said:
Mind if I ask what it cost?
The first time I went, the dealer only charged me labor which was $75. This time there was a charge from GM for the programming files and that was $100 but they didn't charge me labor for it so I'm in for $175 total.
If you have a key I don't believe it matters, the auto stop feature will still shut it down.  If you notice your key is more of a button than anything.  You don't have to hold the key in the start position until it starts, if you just blip it, the starter stays running until it's started anyway.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
