I think GM does the best of the domestics. My Silverado had way better panel fit and paint than my Ram does. I mean, I have an actual run in my tailgate.  Doesn’t really bug me. I’m a realist, not a pretend idealist.
So, if at this point in my life, I choose to identify as a Pretend Idealist, do I get to use the Restroom in the middle, and shower with the girls🤔🤨😬😲
  • Haha 3
I have an open invitation to all of my friends. Take me with you to go pick up your new vehicle. After I show you everything wrong with it, I bet you will think twice about buying it. I have been kicked off of a few car lots and asked not to return.
Grumpy you better be careful about when and where you show that Man Card. In this world of natty light seltzer drinking. skinny pants wearing, white sole dress shoes, and commercials showing teen age boys that don't even know what a lug wrench is you might get sent off for sensitivity training and come back neutered.
  • Haha 1
OP, if you want a new fender where the holes are in a different position by 2mm you'll need to make it yourself.  Having it repaired via warranty will not fix the problem.  The new fender will come from the same assembly line where your original fender was stamped.  "Man Card" holders also recognize this.  The self-described men will roll up their sleeves and fix the issue, such as removal of parts, sanding to bare metal, filling hole, making new hole in correct location, priming, painting, clearing, and reinstalling everything.  There's probably a few more steps involved, but I think I made the message clear.  Is it really worth it to you to do all that for less than 1/12 of an inch?  If so, feel free to write up a tutorial so others can see your work.  Include pictures.  Everybody on the internet loves pictures.
Btw, there's a good possibility you missed an even more obvious manufacturing snafu.  Do the body lines between the cab and bed line up on the driver side?  This is one GM actually has a fix for via the dealership installing shims.
Edited by Transient
I guess we also shouldn’t tell him about the little waves in the metal along the upper bedsides. My 16 and 19 both had that going on.
2 hours ago, shakenfake said:
This sounds like another cringe old people post
“The quality will only improve if you stop accepting mediocrity!”, they shout from their own mediocre late model trucks.
  • Thanks 1
Disclaimer off topic because shakenfake does that well .....🤣  read up old folks......https://www.themodernman.com/success/alpha-male-vs-beta-male.html
"Alpha males, on the other hand, die with satisfaction. They may not accomplish every goal they set or achieve every ambition placed on their heart. But they die knowing that they gave this life their all."  I don't see any posters dead here.......LOL
Edited by customboss
That was on topic. It was my thoughts on this post.
Can't read it though, my work has it blocked. Basically everyone dead is an alpha male from what you posted, we are all beta cucks for being alive.
Virgin vs. Chad | Know Your Meme
  • Haha 1
Very few males wear the same pants today as they did when I grew up. Computers changed all that. Not saying it's bad, but manning up has gone to the way side IMO.
  • Haha 1
Thinking you forgot the "golf cart for two" from a prior post😂🤣🤣😂😮
  • Haha 1
IIRC there is a documented tolerance for bed/cab squareness like 4-5mm, so less than 2mm for bumper to fender is probably within spec.
33 minutes ago, It's Tim said:
Old people should be rejoicing.  Things have improved.  Cars are more reliable, more fuel efficient, and safer in a crash.  We even have seat belts now.  It use to be the backseat was a measure of how many people it would take to push the car when it broke down.  Now it's measured by comfort and conveniences, like cup holders.
If you say that's what the backseat was for 😉
I understand other forms of pushing were going on in the backseat.  I was told that was so there'd be some home grown car pushers when the car broke down.  Lightest one got to steer.
Edited by Transient
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
    • This landing is worse than most. Patchy blacktop with washouts, soft gravel/sand at bottom that washes out with every heavy rain. I tell everyone to put it in 4WD. A lot of them think they can pull out their trailer in 2WD. They end up digging a hole and then putting it in 4WD.  The lake is a pristine lake and has a lot of money on it. There are several wake boats and lot of large tritoons. The people with the money don't want it improved because they don't want more traffic.    Boat Landing 1.jfif Boat Landing 2.jfif Boat Landing 3.jfif
    • How wide are your rims?   Toyo specs 8.5-10.0-11.0 inches. My thought would be rim might be pulling the tire inwards creating a center that is more pronounced.    I also noticed that the spec sheet says max 65psi. So you could be right lowering the pressure to ~40 psi.
