On 1/2/2025 at 2:43 PM, newdude said:
Here's the schematics for NVG246 Autotrac setup for 2001.  Two PDFs below, hopefully they open for you okay.
TY for this information,  I have been chasing other rabbits and now with winter approaching back to getting this 4x4 worked out. I think you are onto something. I am going to connect to and use the front differential electric lock switch on the front differential from a donor S10 ZR2.  I will run one wire from the vacuum actuator relay to the front lock switch and the other from the lock switch to the PCM but still trying to be sure it is red C2 #16 or #19.  I had been looking at the 1695 circuit but I see you are thinking 1694 is the answer?  The NP246 transfer case and the TCCM is from a donor 2001 GMC Sierra. The front diff is from a donor 2003 Chevy S10 ZR2. What is happening is I hear the transfer case enter into 4WD and more noticeably into 4WD Low. Also the vacuum actuator sucks in and pulls the cable at the front differential. But, when I push the 4WD High or Low or Auto 4WD the Van's check/service AWD light light illuminates and no 4WD. So I missed the boat somewhere and I am thinking this is it.  Here is the latest example of chasing rabbits: right now the van is having an updated/improved rear differential work done on the weak 7.5 rear end. I am having an Eaton Truetrac Differential 912A317 and a replacement Motive Gear 4.10 because well it was bang up a bit when the stock differential came apart. Also updating cover by installing a Proform 66667 Perfect Launch aluminum differential cover with Bearing Cap Stabilizer bolts. I sure hope that these improvements make the 7.25" stand up better to be occasionally beat on.
On 1/2/2025 at 8:54 AM, newdude said:
Which transfer case do you have?  Floor shift?  Push button with 2HI, 4HI and 4LO?  Or the Autotrac with AUTO mode?
NP246 with TCCM donor from a 2001 GMC Sierra and a Front diff from a 2003 Chevy S10 ZR2 donor. Yes there is a Auto 4WD button but I am not holding my breath that it will ever work, i just have to get the $H and 4L to play nice with this swap
    • No ETA is available for that engine at the moment in the GM system.   I would start at the dealer.  Try and talk to the parts manager or service manager and see if they can start a CX Connect case and get an ETA from GM on when engines may be available.  If they just check Parts Workbench and say "no eta", they aren't trying hard enough.  They need to do a CX Connect and chat with DPAC to find the ETA.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
    • $4.26 85 oct
