Just had the dealer install 0 dubya 40 instead of 0-20. It's killing 6.2 's and 0-40 is now installed as a fix for 6.2's
I'm pulling at max load on my 5.3 and want best protection during summer months. Asked for 0 dubya 40 instead. Sure, good choice service manager said. Come time to pay bill, it's double the already high price to change oil. Over $300 Canadian. Can't wait for Amazon to open oil centres....lol
So be prepared if you decide to upgrade to better protection!!
  • Sad 1
Wonder if the 5w30, that they put in the 2.7`s, the LV1`s, and the L8T`s is the same price as the 0w20?
The 0w40 has become suddenly famous. This causes supply shortages.
"What is cheaper?
The price of your oil or the price of your equipment?"
And if the truck needs/gets a new 6.2 under that program -- it will be on the the 0W20.
59 minutes ago, Z45 said:
"What is cheaper?
This thread was started on the cost of an oil change.
You guys have Walmart there? If so is the price of Mobil 1 0W40 double the price of Mobil 1 0W20? Same price here.
When I checked a few weeks ago neither Walmart or Canadian Tire had 0w40 dexos R the store. And when I can find it i
the price is considerably more. Please make sure we are comparing 0w20 Dexos1 prices to 0w40 Dexos R prices and not a regular 0w40….
Not sure on the price difference. I'm sure dexos R 0w-40 is more than 0w-20.  So an oil change will be more.
Pretty much overnight, they approved multiple Mobil1 products as Dexos R event though the bottle doesnt say it is. Mobil 1 FS European Car Formula Full Synthetic Motor Oil 0W-40 is pretty much the same price as other 5QT jugs.
Edited by Byrds8
Exactly.  The 0w40 is only to bandaid the passed engines and hope they survive the extended warranty period 😉
    Randy Ginoza
    Randy Ginoza
  • Who's Online   5 Members, 0 Anonymous, 2,189 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
