First Post - Couple 'o Questions
Hi!
Finally had time to sit down and go thru the forums. Picked up my truck in late September - 07 GMC NBS 4x4 Ext cab 5.3l. 2GTEK19J771693911 I absolutely love the truck. Haven't added any mods except a bug defletor and some window guard things. I'm going to wait till spring to mod it out the way I'd like it. I'll also wake that 5.3 up as well.
I needed a 5.3l truck and extended cab, and had to stay within a budget of under $24K. With GMS and rebates I was able to stay within that budget. Didn't have much of a choice from dealer stock in my area, so I settled on a WT model. No bells and whistles, but perfect for my needs. Have air, am/fm and an ipod; the vinyl floor is a godsend... Would rather spend my money on dressing it up than stuff I really don't care about.
But now, I'd like to add mouldings to the doors. Does anyone know if these are available? I see on the SL and SLE's that there are a few different kinds. I'm not trying to make an SLE out of a WT, but just think the mouldings will dress it up and give a bit more protection, etc. I've gone to my dealer twice, but can't seem to get with the collision shop to have them check. Any help/part numbers there would be helpful.
Second, the jump seat in the middle is driving me absolutely crazy. I'm a big guy and it just seems cramped. Plus, it doesn't move, and the armrest/console storage thing isn't working out... Thought I liked it, but it's more of a pain than not. I can pull it out, but would like a console to put in its place. Can a factory console be had seperately as well? I see consoles available online, but at 10" wide, it doesn't make for a great fit.
If anyone has any advice, part numbers, websites, etc., I'd be appreciative.
Thanks
Rick
Welcome to the forum first of all...
I know factory moldings are available through GM for the front doors and rear half doors. You should be able to get them through your dealer. They look pretty nice. GM quit putting moldings on new truck beds about 2003 (or so).
No help on your seat question here...
Well, another NBS GMT900 Work Truck.
WELCOME !
And another who appreciates the vinyl carpet. A person with good taste and values the praticality of vinyl carpets.
Me, I miss the full bench seat. But this is progress, I guess.
Oh, and I think the body side mouldings come unpainted.
Therefore, they will have to be painted before application. How much for a quart of automotive paint?
I think, anyway.
Not sure if you already have it:
VIN 2GTEK19J771693911
VEHICLE BUILD
Merchandising Model : TK10753 -2007 SIERRA 1500 4WD EXT CAB W/T
Gross Vehicle Weight Rating : 3178 kg (7007 lb) Order Number : KVGKHQ
Build Date : 05/10/2007 Build Plant : 27153
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AE7 - CLOTH SEAT TRIM AJ1 - DEEP TINTED GLASS
AL0 - SENSOR INDICATOR, INFLATABLE RESTRAINT AM1 - SEAT ADJUSTER, DR MANUAL LUMBAR
AM7 - REAR BENCH FOLDING SEAT A10 - WINDOW
BG9 - VINYL FLOOR COVERING C49 - REAR WINDOW ELECTRIC DEFOGGER
C5W - GVW RATING - 7,000 LBS C67 - MANUAL AIR CONDITIONING
DE2 - BLACK FOLDAWAY EXTERIOR MIRRORS DK8 - CONSOLE, OVERHEAD DELUXE
E63 - WIDESIDE PICKUP BOX GT4 - REAR AXLE - 3.73 RATIO
G80 - H.D. RR AUTO LOCK DIFFERENTIAL JF3 - DISC BRAKE
JJG - FRT END SUBASSEMBLY KG3 - 145 AMP ALTERNATOR
KNP - EXTERNAL TRANS OIL COOLER K47 - HIGH CAPACITY AIR CLEANER
LY5 - VORTEC 5.3L V8 IRON BLK ENG W/ACTIVE FUEL MGMT TECHNOLOGY M30 - 4-SPEED AUTOMATIC TRANSMISSION
NE1 - 50-STATE EMISSIONS NQG - FLOOR-MOUNTED TRANSFER CASE
NU5 - EMISSION SYSTEM CA BIN 4 NX7 - 17" STEEL PAINTED WHEELS
N86 - 17" FULL-SIZE ALUM SPARE WHEEL OSG - ASSEMBLY PLANT, OSHAWA, ONTARIO
PCY - WORK TRUCK TRAILERING PKG: *HIGH CAPACITY AIR CLEANER *TRANSMISSION COOLING SYSTEM *H.D. RR AUTO LOCK DIFFERENTIAL *H.D. TRAILERING EQUIPMENT *HANDLING/TRAILERING SUSP PKG QVL - 17" P265 ALS, BW TIRES
R6J - CUSTOMER DIALOG NETWORK R6K
R6P - PREMIUM PAINT R9L - SPRING WHOLESALE FLOORPLAN PLUS
R9N - LEATHER SEAT TRIM SAB - ACTIVE FUEL MGMT ENGINE ID
SAF - SPARE TIRE LOCK SLM - STOCK ORDERS
TFE - SALES INCENTIVE-COMMITMENT PLUS T74 - HEADLAMPS CONTROL AUTO, DELAY
UE1 - 1 YR ONSTAR SAFE & SOUND (ASK DLR ABOUT TURN-BY-TURN NAV UPGRADE) UJ6 - TIRE PRESSURE MONITOR SYSTEM
UM7 - AM/FM STEREO UQ3 - AUDIO SYSTEM-HIGH PERFORMANCE
VB3 - CHROME REAR BUMPER VG3 - BUMPER, FRONT CHROME
VK3 - FRONT LICENSE PLATE MOUNT VR4 - WEIGHT DIST HITCH PLATFORM
VXS - COMPLETE VEHICLE LABEL V73 - STATEMENT OF CERT. U.S.
V76 - FRONT TOW HOOKS YD3 - BASE EQUIP FOR SCH GVW PLATE
YD5 - FRONT SPRING - BASE EQUIPMENT YD6 - REAR SPRING - BASE EQUIPMENT
ZK3 - PULL AHEAD IDENTIFIER ZRS - SPARE TIRE
ZY1 - SOLID PAINT Z82 - H.D. TRAILERING EQUIPMENT
Z85 - HANDLING/TRAILERING SUSP PKG Z88 - GMC TRUCK NAMEPLATE
1SA - WORK TRUCK PACKAGE 1SZ - OPTION PACKAGE SAVINGS
59U - SILVER BIRCH METALLIC 6SY - COMP FRT LH COMPUTER SEL SUSP
7SY - COMPONENT SUSPENSION 88B - DARK TITANIUM
88I - DARK TITANIUM
SERVICE INFORMATIONAL ITEMS
Type Number Description Posted Date Status
EI 07082 POWER STEERING FLUID LEAK AT GEAR/RACK, REF-TSB 07-02-32-002C 08/14/2007 See Bulletin
EI 07321 INNER DOOR PANEL RATTLE NOISE / LOOSE - REF. TSB 07-08-110-010. 12/13/2007 See Bulletin
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
12/06/2007 149321 # C8819 - INFLATABLE RESTRAINT FRONT PASSENGER POSITION SENSOR REPLA 4140 miles
12/06/2007 149321 # H0257 - SHOES AND LININGS, DRUM BRAKE - REAR - BOTH - R&R OR REPLA 4140 miles
09/21/2007 024383 # N0680 - BULBS, PARK AND TURN SIGNAL LAMP (RIGHT) - REPLACE 112 miles
09/20/2007 144703 I Z6999 - PDI RELATED FLUID ADDS 50 miles
05/10/2007 A93911 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
