Dic / Info Center
04 yukon 2500
I messed with the suspension and did a 3" block in the rear and new keys up front
so the air tube or whatever it is, is disconected from the shocks,, its not autoride because of the 2500
its an (electronically controlled suspension)
the dic tells me "service suspension" how do iclear this or does if just stay there, thanks
Autoride/autolevel DIC warnings/SES lights
after suspension mods ?????????
Time for a trip to the dealer and a visit with the Tech 2 machine.
If no luck with that then its time to do a PCM burn/mod to eliminate
the autoride/autolevel programming. Common burb/denali issue.
Read this:
http://www.gm-trucks.com/forums/index.php?...autoride+shocks
thanks for the link, someone else had mentioned that about the bcm.. when i asked the dealer they just said they werent able to do any reprogramming of a bcm
