Smart Phone Poll
Josh
Smartphone OS
147 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Ok, lets get the new technology forum off to a good start... Tell us what smart phone OS you have, and what you're planning to upgrade to. Comment and tell us why you chose it, what you upgraded from, if you are brand loyal, etc.
I'll start it off.. I have a Droid 3. Before that a BlackBerry tour. I like the Droid but it's disappointing to not be able to upgrade to IceCream sandwich.
  • Replies 104
iPhone 4S here...very happy with it. When I'm eligible for an upgrade in about a year from now, I'll explore some other options, but I like my iPhone a lot.
I currently have the iPhone 4S, I like it alot and when I upgrade I will most likely stay with Apple. Previous to the iPhone I had a Droid X it was nice but the iPhone is much better for me
You can update to a new phone Josh. My Razr has Ice Cream Sandwich. I've had the Blackberry Curve 8900, old iPhone, and Palm Treo. I've been brand loyal to Motorola for a few years with the orginal Droid, Droid X, Droid X2, and now my Droid Razr Maxx
Got the RAZR maxx too, besides the new DROID DNA, no other phones surpass these things IMO and many more.
Yea, I can of course, but just waiting till the contract is over on this one. I upgrade every 2 years. in 8 months or so I'll be in the market :D
I usually do yearly. This past time was year and a half and I paid full retail for my phone
I have over a year left. All in all the 4S I have is great, I'd just kinda like to try out a Droid M. Well who knows what the equivalent will be in a year, probably the Droid XX10 DNA HD 5G. :lol:
and razors will have 6 blades!! :cool:
lol
Damn I still enjoy my 3 blade razor. Josh, did you think about a 3rd poll for brand loyalty if one, Such as my last 4 phones have been Motorola
I have a htc thunderbolt, looking at the gallaxcy s3
Sent from my ADR6400L using Tapatalk 2
