Yeah I'll see if I can get one next to a stock silverado. I do have a rough country 1.25 body lift I'll eventually will put on the truck. So that'll give you an idea of 5" too.
That would be perfect. I'm just waiting for my wheels to come off back order and then I'll have to make up my mind and get something ordered. Thanks again!
2014 Sierra All Terrain
Lift is the 4.5 Zone
Still the stock tires and wheels. I'll upload new pics soon with the kmc XD Monster 2 20x10 -24 with the Nitto Trail Grabber.. Tire size will be 295/55/20.
Was anything special required (spacers) to use your OEM Wheels? Or do they bolt up as normal?
The oem 20s bolted right on, no problems at all!
no rub ?? war tires are those and rim specs plz
I just had the truck lifted this weekend. It's a 4.5 zone suspension lift. The wheels and tire on it are all stock. It will be a few weeks before I install the new wheels and tires.
Nothing rubs, and I'd say the truck drives just as it did stock. Great lift
What 4" kit do you guys recommend? How is the zone 4.5" kit? or the McGaughys 4" kit?
Edited by chevydeth
12" Third coast lift. 20X12 Fuel Mavericks D260. 35" Nitto G2's
Upgraded my Zone 4.5" lift last week. I had some custom built Icon Vehicle Dynamics coilovers and put on. Along with IVD UCA's. This removed the strut spacers. Rides about the same as stock on the road, but on off road and bigger bumps just eats up the road and is much better! No more bouncing around, truck just feels planted to the ground!
Nice truck Man!! Bet it does ride nice.
I've got a 2wd I'm thinking of getting 3.5" spindles with coilovers for about 4.5" total. Should ride cushy!
Thank you! They were pricey but looks sweet and ride great! sdhq off road was who I went through to get them. The guy named Louis was awesome to work with. Strongly recommend them in you need a custom setup
I ran that kit on my 13. Only issue I had with it was the wheel back spacing required to run it; didn't leave a lot of tire options unless you were willing to do some trimming. Loved it and I miss the ride and handling. Will do the same with the Duramax when the factory shocks go. Pics are in my gallery.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
