I got the 6'' basic kit as money was an issue for me and the new coil overs, to me, wasn't worth the extra cost. The rear shocks do provide a quality ride so I did go that route.
I was definitely in the same boat, then the new version fox shocks came out and I was just curious. I probably will pick up the fox tears being they are fairly inexpensive
Love your trucks color btw, had a burgundy 01 Silverado and. Red jewel 11' 2ss camaro. Almost went with it again but I needed to break the trend!
I've got the Zone 4.5" lift on order, and am sure that it is the size and stance I want. But if I wanted to increase the height in the future, is there a way to easily upgrade from the 4.5 to the 6.5in? Would it just be a larger block and drop for the front that re-uses all the other parts? Or would an entire new kit be needed?
Turned out great! The wheels look good. They look like they have a pretty deep lip for a 20x9 and positive offset. I might have to switch out my fuel nutz for a set.
Thanks, it seemed like it took me forever to find what I wanted. I like a basic 5 to 6 spoke wheel with some type of lip. I bought the wheels site unseen and am pretty happy with the choice.
After the lift I put on this past weekend I'm thinking I would like 1"-1 1/2" inches added to the rear. I was debating on doing the Add-A-Leaf with Zone but was unsure if it would stiffen the ride in the rear. Any suggestions?
Thanks I truly love the color also. This is the first non black vehicle I've owned and went to buy another black truck until seeing this one on the lot and immediately knew I had to have it.
Has anyone done the 6.5" zone or another 6" kit with the bottom spacer left installed from a rcx level? Wondering if i can keep my angles manageable and run the 6.5" the spacer on bottom the aal in the rear and 37x12.50 on my factory 20s
Sweet man. Anytime you get a chance i know how it goes.
Sorry it took so long man we have been busy as hell...
awesome man that's the 6" right? going to do spacers in the rear to even it out? if so what size?
Ok finally got through this one after weeks on my phone, screenshot a bunch of pics but still a couple questions.
Im down to the Zone 6.5 and the Fabtech gen II/procomp 6 looking to fit 325/20 or 35x12.5x20. With these which would I be able to use with stock 20 wheels at first and change out later. Obviously theres a huge price difference between zone and fabtech but is there any noticeable difference quality wise. Last question, I think the only one of these that retains the factory track width is the fabtech but ive read the turning radius becomes even worse, any expertise with that?
Thanks for all the help, sad it came to an end after 153 pages
Edit: Also what am I looking to spend install wise in orange county, los angeles, CA (recommended shops if from this area)
Edited by Bpun2016
Thanks for all the info in this thread. I ended up with the following setup.
4.5" Zone suspension lift
20x9 (+10 offset) Hostile Hammered Wheels
33x12.5/20 Toyo Open Country MTs
1.5" Wheel spacers in the rear
Before:
Just the lift without wheels (looks lower in the rear because I had all my factory parts and crap in the bed weighing it down):
After:
Your truck looks great. In the pic with the factory wheels, did you have the 1.5 inch rear spacers on? Also, does the 4.5 inch Zone still leave a slight bit of rake?
37x13.50 Toyo Open Country MT and 22x12-44 Fuel Maverick D260s
what size lift are you going with? Edited by Gonzalez210
Thanks... Are you talking about the 1.5" spacers I added to the wheel or the factory 1.5" block since your mentioning the rake?
There is no rake with the 4.5" zone. I'm thinking about going the add-a-leaf route in case I ever haul anything I'm not a fan of the squatting look. The way it sits without anything it seems perfectly level from front to back.
Edited by randomposter
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
