But they aren't cause the Zone uses the original strut and adds a spacer while the BDS replaces it with a brand new strut to compensate for the lift. Correct me anyone if I am wrong.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Zone uses the same replacement strut as BDS on the gmt900 and will be using it again on the k2xx kit according to my connect at Zone. You can't lose with either kit though
Sent from your sister's house
The kit that I always see with Zone just adds a simple spacer.
correct, but they WILL be offering a full strut soon just like they do for the gmt900s. I have a gmt900 and have the Zone 6.5 with the full strut
Gmt900? And how much did it run you?
GMT900s are 07-13s and with the front skid plate and nitro rear shocks I paid $1200 and again that was WITH full struts
I've owned 3 BDS kits, 2 Superlift kits, and 1 Zone. I've installed both superlifts and the zone with friends
Edited by jimmyboy8301
Super clean Abearclaw. Im sold, the 4" lifts look way better with AT tires which I have to run, 6" better with MT imo. One last thing, any pics of the back to front looking down the side for track width difference. Thanks again
Yeah no prob here's a few pix
6af11a6ad40502567e73e2408e0e6420.jpge8fa727c3ca5c707826d8b8a6281c39c.jpg42bdeb5673e2ff7ec2453032ad79662e.jpg
If you want any other pix specifically let me know
Thank you I appreciate it. I'm super happy with the 4" although every now and again I think about adjusting it to 6" and after a solid minute say,"nah" lol. And I agree with you on the tires. I had toyo at2 extremes when I had my level but wanted something a bit more aggressive for the lift and stepped up to the rt's. I do have a pic of the side and I can always snap more
Even tho the fronts stick out about an inch it doesn't bother me and I don't notice it anymore. Of course more aggressive offsets will exaggerate things a bit.
Edited by Abearclaw
Thats perfect! no spacers needed. Well I know what I have to do this weekend
cf372db73350069b45e4ae4a08432383.jpg4766d902652ec94e149aa5389b6736ac.jpg6ec62de1af35e0687f0ba7bc03afe4f2.jpg7d225a99b38b624b5478863ad7ec020e.jpg
Finally got my lift, absolutely love it
  • Like 6
2015 1500 HC w/ 2.5 rc level with blocks in the rear fuel maverick trophies 20x9 +1 offset with toyo at2 xtremes 295/55. Removed front mud flaps that's the only modification no rubbing or trimming ill get some pics loded in a bit
How are those headlights? Do they make a huge difference at night? Was it an easy install?
Any body running the Fabtech 6" Basic System w/ Rear Performance Shocks - 2014-16 GM K1500 4WD? This is the front lift needing opinions on this kit? Brand new it runs $1995. Found the kit off a buddy's friend for $500. He upgrade to 9" lift.
Looks like you got the lift I am looking at how does it ride any complaints?
To be honest I think it rides better than stock, only thing is your blind spots tend to get larger but that's expected.
    • 3.19 @ Kroger’s in Montgomery Tx
    • We have now!  2027 GMC Sierra  Early look, but I'm a GMC guy and so far I think I like the looks of the Chevy better.
