On 2/20/2019 at 10:17 AM, big papa said:
if i install a Zone 4.5 or 6.5 lift.  what size spacer will be required to get me home on OEM 18" wheels?
Thanks.
probably 1/2 - 1"
Thanks.
If backspacing matches the 20's (6.06") then you'll need at least 1.06" to clear according to fitment notes for 18's (5" max backspacing).
That said, that's clearance for a 33x12.5" tire. I don't know about knuckle clearance or narrower tires...
I wouldn't want to run a spacer less than 1". Anything smaller and you're basically limited to slip on spacers. I would much prefer a hub/wheel centric spacer with dedicated studs.
I took the truck to the outlets (1-1/2 hr one way) with the wife. It was also much better on highway then the RC lift ever was. I am also loving the setup—I noticed it’s just a tad bit higher than my old setup was.
The sun is finally out today, so I was looking around under my truck.  Does this look like the rancho leveling shocks?  I've only ran the Bilstein 5100s and regular leveling kits in the past but this kinda looks like it.  Well maybe they are the regular rancho stocks, kinda looked like the leveling ones from a certain angle, but I looked again think they are just the stocks.
Edited by SuthrnZ71
Those look like they are just the stock Z71 Rancho struts.
Maybe just needs to settle in looking good
Those are factory ranchos. What lift is this? Awful CV angle..
Been a while since I've posted any pics. But how j finally got myself a set of wheels and tires commensurate with the 3.5" RC suspension lift.
20x9 0 offset XD 828's with Nitto Ridge Grapplers 265/60/20. I got the set for $1200 with about 6k miles on them.
Yeah, the geometry on those are gonna make them tear themselves apart.  Premature wear on the differential should be expected too.
Not tryng to be a jerk but arent those almost the exact same height and width of the stock tires?
These are 33" tall on the truck and my stock ones were 31" tall.
My stock tires were 265/70/18. I went to a 295/70/18 without a lift or level. I suspected that stock setups varied from year to year and model to model.   Nice truck man!
It's 6 inch pro comp, although not sure why the stock ranchos would be on here,  not as bad as when I put the RCX on my old gmc sierra, but I still think there must be a additional spacer or something cause yes it does look a bit steep.
Edited by SuthrnZ71
Are any of you guys upgrading the upper control arms with your lifts ? Low priority or just don’t need them?
    DM22
    DM22
  • Who's Online   1 Member, 0 Anonymous, 2,793 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
