2 hours ago, arkenzo said:
Are any of you guys upgrading the upper control arms with your lifts ? Low priority or just don’t need them?
I would if I was doing any of the stretched out levels.  I think some even come with arms.
Is there would be absolutely no benefit to getting upper control arms with suspension lifts ? Unless your balljoints go bad I suppose.
Anyone have pictures of CV angles of the zone 6.5” kit? I had a 4.5, but looking to go up this time around I think.
Old truck that was totaled out. Zone 4.5, Bora 1.5” rear spacers, 20x9 0 offset XD820, 305/55/20 falken at3w. Zero rub, zero issues. Well, except for being tboned on my way to work.
22860d51bd75f180341f2a241c9912d7.jpgthats the Zone 4.5” set at 5.75” with the 5100s. Another 3/4” would be fine
That’s perfect. I remember my 4.5 being perfect but wasn’t sure how bad the 6.5 would be. I thought about modifying the strut spacers to 5.5” so it’s a happy medium between the 2, because I only want to run a 33, not a 35. Been there done that on a 1500, no thanks!
If you want an in-between to the 4.5 - 6.5 just do the 5100s, then you can run it at 4.5 , 5.25 , 5.75 , or 6.35
Those angles look good.  I'm getting Zone 4.5 tomorrow, installer said later I could get 5100s or some people slide in a small spacer to level up lift.  That truck look great.
Thanks!
Finally got a decent day to clean up the truck a little bit. Here's my 4.5" Zone with 33x12.50x20 Toyo R/T and Hostile Sprockets.
Pretty happy with how it turned out. I will be ordering 35x12.50x20 Toyo A/T2 Extremes and Fuel Blitz wheels as a summer setup.
20x9 sprockets?
2 minutes ago, Criscone said:
What offset? Looks like + something?
I want to say +10.
Edit: for sure +10, I just checked out the specs on Hostile's site.
Edited by buckeye6
CST 4 1/2" Bracket lift, 20x9 Hostile Rages, 285/60/20 Toyo RT's. Will be going 20x10 when this Winter is done. Also adding a Deaver Mini-pack to the rear to replace the CST 3" block.
First time posting, 2015 GMC Sierra SLT 14k Miles
22x14 -76 American Truxx wheels
325/50/22 Nitto tires
McGaughys 9” lift with add a leaf set at 9.
2.5” Bora Spacers in the back.
  • Like 5
Love it man how high does your truck sit to the point of the roof antenna?
    DM22
    DM22
  • Who's Online   6 Members, 0 Anonymous, 1,092 Guests (See full list)
