Yes they will. It is just that the 2.5 will be smaller that the 3 (obviously, lol) and you will have just a little space around the perimeter of the lenses. Not a big deal.
Great thanks, was hoping the 2.5"s would line up
I'd like to use my 55w bulbs and ballasts for awhile at least since I have them as they're new with that fxr kit, would the harness I'm using now for my 35w sierra spec kit work fine with them? I like the new xb ballasts much better that I'm running now than the old 5five ones that came with the fxr kit I have so I'll probably get some 35 d2s bulbs to run off those eventually, try them both out. Need the straight adapters too I guess do you have different bulb options and adapters available on their own?
If you email me at [email protected] (reference this thread) I can create a bundle for you.
Hey everyone just a quick question, I have a 2015 Silverado 2500, looking at a morimoto kit for my truck, I can only seem to get up to a 6500k bulb? Can I get an 8k from them? Also what's the best option I have for my fog lights? I seen in some of the walkers posts I seen a guy used some cool projectors for the fog lights?
Hey bud. 8k is not very bright. 6500k has a blue tone to it.
I ran the 55 (50w) in the 2015 Silverado 2500HD stock projectors with no issues.
Just replaced the stock projectors with FX-R projectors. Definitely a severe upgrade over stock. Now running 5500k Morimoto XB bulbs in the FX-R with the same 55w ballasts.
Crystal clear and very pretty cutoff, but I am having issues adjusting the cutoff where I like it. Once I get the cutoff right we will be in business.
Is there anything I could have done wrong with the install to cause them to point lower than stock or is that normal?
If its normal I am probably going to add washers to the front-bottom screw in between the headlight mount and the body of the truck to prop them up a little bit more. Does anyone have any other suggestions?
Edited by Menteleum
I don't have a 2500 but I do have the 1500 I had to use washers to get my light to line up inside the headlight. It took me about 4 tries to get my lights set I still had to use the adjustment screw it went from people pulling over and flashing me to the random flash
Maybe one of you can help with my issue. I recently installed the TRS Sierra Spec kit on my 2014 GMC Sierra SLE. I can not seem to get the lights to function properly in the Auto position. If I put it on manual everything works perfect.
My issue is in the auto position the lights either come on and turn off almost instantly or they will flicker like crazy. The relays will also start making a buzzing noise. I have contacted TRS and they sent me a new capacitor link for the kit. I have installed that and the issue is still there. I don't know what to do at this point. I know this has to do with PWM and how the DRLs work on the SLE model, but I just can't figure out why the capacitor isn't fixing the issue.
Did you try rotating your capacitor plug? Posting and negative polarity reversal. Try it.
I tried that with the older capacitor link, and nothing changed. I will try that with new one. I have also sanded away all the paint for the ground wire on the capacitor link.
Edited by TXSierra507
I want to get the Sierra Spec TRS kit for my 14 SLE aswell. Only thing that concerns me is the DRL'S on that model. Seems like it was causing TXSierra507 issues... (Hope you get it figured out!!)
Main concern beyond just getting them to function properly is what kind of additional ware & tear are the HID'S gonna take with the them also being the DRL's?
Probably just have to remember to manually turn them off every time I get in to drive...
Took some pics tonight showing the difference amongst setups. I used just one projector in the comparisons.
Factory 2015 GMC Sierra projector and bulb
Factory 2015 GMC Sierra projector with 35 watt 5000k Morimoto HID setup
RX350 projector with STi clear lenses/tuned with 35 watt 5000k Morimoto HIDs. *FXR has same/similar performance
WOW! I have been on the fence about doing a projector swap for a while now, but this just makes me want to throw in the towel and go ahead with it. Just last night it seemed to me like my HID's weren't that bright anymore. Unfortunately I think its just my eyes used to the output and wanting more. It looks as if with the RX350 kit, you get much much more.
Is there any significant performance difference between the FXR and the RX350 kit? Is either of them better or both perform about the same?
Also if I went with the RX kit, do you sell just the projectors without the relay, HIDs, etc? I have HID's now, so I can just use those.
Edited by Kerrslight
I was having the same concerns installing this kit on my SLE. Was having problems as well when I first installed. The DRL's would not come on when I was in gear and sometimes wouldn't turn on at night either. To fix the DRL issues all you need to do is switch the polarity in the capacitor. Once I did that everything has been working the way its supposed to. No complaints. Running the 35w 5500k.
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
