They stick out right at 2' right now. They should be real close after I install the flares.
Got my Rough Country 2.5" level kit installed with 20x10 (-19 Offset) monster rims with 295 55 R20 nitto trail grappler tires. :D Rides different but not bad. I did not drive it far enough yet to see how the mileage is effected, but it seemed to still be dropping into V4 mode fine and the instant mileage looked to be only slightly lower. I will have flares added to it by this weekend I hope. I think it is coming along. So far I am completely happy with this :chevy: truck.
I like this, but I don't see how that can not rub something during a turn. Hell, I was going to go 20x9 with a -12 offset with 295s and it was going to rub.
what bluewrapper said. with 72lbs tires 12.5" wide running at 75+ I lost about 5mpg but if you run 65mph and below I can still clock over 20mpg. this was taken this morning
but this was going to Colorado at 75-85mph 4000ft sea level at that point uphill into a headwind.
5ee193e4-54f0-413b-905a-f798a025c2bd_zps
it will be off if you didn't have the ECM updated for your tire size. I lost 2mpg that's it.
Here's mine, 2" RC kit.
any rubbing issues. Looking at same setup with 275/70/18 x 9 0 offset
No rubbing issues at all, I put the tires on before I leveled it and still didn't have any issues.
It had to be trimmed just a little. I did not think they were going to be able to make it work either but I am completely happy with it.
Your truck looks great! How much trimming did you have to do and where? Very curious I am going to order my wheels and tires today and if I can go with a 20x10 I will!
About two 2" right now. It is at my painter's getting the flares put on so it should be close to flush when he is done.
at the front of the front wheel well you should be able to just move the inner wheel felt looking stuff forward without much problems. In the rear you have to trim some at the bottom of the fender where the black plastic cover is. it is hard to explain because I did not do it I just seen it after the fact. If you look at mine now you can not tell it has been trimmed at all. Sorry I know this does not help much but it is all I know. It is little enough that just looking at it you can not tell it has been trimmed.
Ok great! If it is not much trimming then it is worth it to me to do the wider wheels. I love the look of the wider "tough" stance. Thanks!
I went to the dealership a little while ago to see about having my seat movement fixed and saw this on the lot and thought i would post it up.
2" level (skyjacker I believe) on rockstar2 wheels wrapped in nitto 295-55-20 trail grapplers.
I think the parts guy said they were +18 offset
46A7AFBB-79B1-4B88-92C2-6B6EAD7922F4_zps
DA88BACA-FB1E-4B32-8A3E-0677B2892261_zps
Edited by Tim99GT
I don't doubt that, but it's just a lot more of a swing from different driving conditions was my point.
installed my 2.5" level this weekend as well as the 22" CK375 wheels and 285/50R22 (33.2") Terra Grapplers. Next up 1.5" Body Lift...
20140309_164049_RichtoneHDR_zpsda95z5yh.
20140309_163922_RichtoneHDR_zpssc3pelut.
20140309_181408_RichtoneHDR_zpshpzrn76q.
I really like your setup. Where did you get these wheels?
2.25" Ready-Lift Level Kit, Rear Stock Block.
Front 39"... Rear 39"
BEFORE:
AFTER:
Edited by Luster
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 413 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
