Just finished up the Ebay 2" Leveling Kit (Summit Performance ($31.99). I never removed the wheels. Loosened Sway Bar links, Pop the upper ball Joints, install spacers bolt everything back up.
Stock
2" Level
How was the quality of that summit racing kit? They look really nice in the pictures and have by far the best prices I've seen.
Did you go with the upper or lower strut spacers?
Here is mine (GMC) and my buddies (Chevy). Both have 2.5 Rough Country and 1.5 Zone Body lift. His has 18s with 33"BFG. I just bought some 275 60 20 Terra Grapplers. Get them mounted next week on my factory rims.
Before(top) after(bottom) body kit
2.5" level, factory rear block and 295-60-20 toyo AT II
Truck looks badass. exact tire I'm stuck on ... Any rub issues ?
No rubbing at all. The wheels are factory
Disregard just read the answer lol
Is this one of those new fancy photo filters?!? or just trying to oversize the photos... With the level and body lift, do you have or can get pictures showing clearance at closest impact points? Really want to run this setup with larger tires. Close to 35's. Thanks.
No filters applied other than just some color enhanced. I have a clearance pic of my buddies Chevy. Here you go. Wheel at full lock.
Excellent. Thank you. :cheers:
Im about to do the RC 2.5" lift/level. Im going to with a 275/60r20(33x11) on either fuel mavericks or some rockstars. The mavericks are offered in a +1 and =14 offset, and the rockstars are offered in a +10 offset. My question is would have a problem fitting any of these wheel tire combo? any idea what offset I should stay around? thanks for any input!
I have a 2.5 rough country level, can I go with 285/65/18 Toyo at tires? I don't want rubbing though
Yes, as long as you don't have negative offset wheels.
Any one had any success with a 2.5 RC level and 285/65/20. Really set on mt atz p3 was about to make the purchase today on 275 but if I can squeeze a 285 with no rub I'd rather do that
You'll have to stick with a stock offset and might possible be some trimming needed
struggling with size of tire.I am looking to fit 325 65 r18 on my 4x4 with a 2.5 lift leveling kit. The tire size is listed as a 325/65R18 = 34.6X12.8R18. seems like it is not going to happen as far as sizes go. I know they will most likely rub but how bad and where? does anyone have any ideas or if anyone is running a lift and is/are still rubbing? please let me know asap im getting new tires this coming weekend and I want to go big just in case I add the body lift kit as well. Just hard to find good tires that I want in size18. thanks in advance cheers.
Wishfull thinking I know but I am asking for thoughts and constructive ideas, not negative nancy "thats dumb" ideas lol.
Edited by travalan21
You'll need probably a 4" suspension lift to run that tire. Don't even try it with a level kit.
