Hey does anyone know if 295 60 20 toyo open country at 2 extreme would fit on a 14 sierra with 2 inch front level kit on stock 20s???Thanks
If you look at the post 2 posts above yours, you should get a good idea.
Ya i saw that but those tires are over a inch smaller in dia..not worried bout the width!
I know its probably been asked before, but I can't find a decent answer to it. Will the Rancho Quicklift struts fit the Z71? It says "excludes Z71" on their website, but I'm not sure why it would be excluded. If the Quicklift doesn't work, will the Bilstein 5100 ride adjustable work?
Anyone have some pics of a truck running RC 2.5 leveled on Toyo Open Country MT or Cooper Discoverer STT on
285/65/17 or
285/65/18 or
Very close to that size, any opinions y'all have let me know, thanks in advance!!
I run cooper discoverer ATP with Xd's offset of +18 run run on 285-75-17.. this puts it just a hair outside of the fender but i say its dead even. putting on a new set monday going to a cooper st/maxx 295-70-18 TIS wheels with a 0 offset, it might rub a little not sure
Definitely keep us posted on the 295 70s. I really want to run those same tires but not sure on clearance issues.
will do, i also have a 2.25 level kit, the current tires I run are 33.75 tall and the new set they will run 34.25 and I calculated about 1" of easy clearance left so they shouldn't rub
This was always my dilemma. There are a few guys on here running 295/70/18 that do rub - I forget which offset though.
295/70/17 is not a problem and the way im leaning
Diameter wise 295/70/17 will likely be fine it will be offset that will be the question. 295/70/17 is roughly 33.3-33.5"x12ishx17. Again like most 33-34" tires the thickness will be the issue. I suggest +12-0-12 offset.
I think AZ has his 295/55/20s not rubbing with +19 offset on fuel Mavericks. I've since switched my choice to method mesh at 0 offset. Should he good to go on either 285/70/17 or 295/70/17
yes rancho quick lifts fit Z71 trucks
Thanks for the reply.
Anyone run Quicklift with 275/70-/18, stock Z71 wheels? Any rubbing?
No rubbing.
My tires are weak lol hate them, waitin till I do my 7" lift to change them tho
My Current Setup,2014 Silverado 2LT Z71,RCX 2.5 Level Kit,NittoTerra 33x12.50R20Lt's,Fuel - Octane D509 20x9 -12 Offset,All Chrome Plasti-Diped
My Up Coming Mod's,McGhauphy's 7"-9" Economy Lift Kit,Federal Couragia M/T's 35x12.50R20Lt's,OEM Tow Mirror's,Bushwaker OE Fender Flairs,Gtr Lighting Led Conversion Kit's 2,200 Lumen(High,Low,Fog),Black Spyder Venom Bull Bar,Iron Cross HD Step's.
Edited by 2014Sandylifted
No rubbing.
I'm surprised those don't rub. Good to know though my wheels have the same offset
Got them on today, they look great will post pics later. a very slight rub on the wheel well on the backside middle of the front tire, very minor trimming will fix it, theres no rub on the front fender side. tires stick out almost an inch outside fenders
    juggernautusa
    juggernautusa
  • Who's Online   4 Members, 0 Anonymous, 753 Guests (See full list)
