HondaHawk, can you post a pic down the side of your truck. I would like to see if your set up has the tires sitting flush or outside the wheel wells. Thanks
They stick out just under 3/4". Here's the best picture I have at the moment.
Thanks, I'm looking into 285/70 17 (33x11.5) on either a 0 or +12 offset. It's about a 1/2 in difference with these two offsets. How bad does it throw mud on the side of the truck???
Not bad. The body panels on these K2's tuck in quite a bit so even a tucked in setup gets plenty of mud thrown on the sides without mud flaps. The Toyos throw more rocks than my Cooper ST Maxx's unfortunately...
Added 1.5 zone body lift to RC 2.5 level so my 305 55 20 would not rub with 0 offset. No rub at all at full lock. Love the ride also.
Sent from my iPhone
using Tapatalk
Sent from my iPhone
using Tapatalk
Looks good fuse glad that solved your rubbing issue
I did a Suspension Maxx 1.5" and 22's with 305/45R22 Nitto Terra Grapler G2's.
I like the way your wheels blend with the color of the truck.
Got the tires put on a few days ago. Tires are 275/70R18 Toyo Open Country M/T.
I also have a RC 2.5 leveling kit, with the rear blocks that came with the kit installed(some people didn't use them).
That looks really good man. [emoji106]That color is really starting to grow on me.
can anyone tell me the correct way to disconnect the electric power steering plugs? At first glance they don't seem to be your typical plug bayonet types, and I really don't want to break them. Thx.
Turned out great. I like it!
Finally broke down and did it. RC 2.5" level. 295/55r20 Nitto Trail Grapplers. Air dam removed.
Thanks man, I love how it turned out! Now its time to find something else to do to add to it haha
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
