Anyone know the biggest tires that can be put on 22" GM rims with a RC 2.5" level while having no rub and no offset?
I know this has probably been discussed many times on here but I have yet to find a clear answer. I have a '14 crew cab sierra all terrain and I am going to get a 2" leveling kit from rough country. What is the tallest tire I can fit on my truck once I install the leveling kit? I'm looking more for height, I like the width of the stock 275 55 20 tires. I will be installin the tires on the stock all terrain wheels. Any complaints with the RC 2" leveling kit on the newer trucks? I installed one on my '09 sierra when I had it and didn't have any problems.
275/60 with 2". I think you can do 275/65 if you do the 2.5".
If you like the stock width, you'd probably be safe to go with 275/60r20s or MAYBE 275/65r20s
Anyone having ball joint issues with the 2.5" kit? I have the 2" kit and am not happy with it. Going to add the other .5 inches soon and wondering if I will have issues with ball joints?
You'll be fine at 2.5" i wouldn't go any higher without doing a proper suspension lift.
Finally finished all the mods, here is some info for those looking for it.
- 2inch rough country leveling kit
- 305/55/20 Nitto Terra Grappler G2
- 20 inch Fuel Maverick Wheels with a 20mm Offset
And before any one asks, No rubbing on the fender lining and suspension at full lock. I also didn't trim a thing.
Nice looking truck! That's pretty much the exact same set up i'm looking to run. Any chance you could upload some more pics? Maybe one down the side, or from the front showing the stance? Thanks!
I know I asked before but didn't really get an answer.
Can I do Fox coilovers at Factory height and then use a spacer to get my level? I assume fox's would improve ride quality greatly but if they are too compressed they'd be stiff. Using a spacer on them might be the best of both worlds
2.5" lift, also came with a spacer to do 3" lift in the front. Then I put Firestone airbags in the back to adjust the ride height in the back when I haul/tow. Keep about 10psi in them and it lifted the back around 3/4-1" so I have a little rake in it. Tires to come here soon and maybe rims. Also thinking of doing a 1.5" body lift.
Before:
After:
Would you. Happen to have more pics?
18" problems haha I read that 295/70/18 rub with RC 2.5" on stock rims. I love the Z71 rims do i went with the safe bet 275/70/18 Cooper Discoverer. Love em
2015 Z71 Silverado 5.3 V8
Bilstein 5100 adjustable strut 2" Level Front
Bilstein 5100 Rear Shocks
Toyo Open Country AT2 275/65/20
MHT Fuel Nutz 20x9 wheels
Magnaflow 18" Dual Exhaust
Zero Rub
Couple of pics including a Before and After
Edited by second2none
    DaleB
    DaleB
  • Who's Online   5 Members, 1 Anonymous, 1,246 Guests (See full list)
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
