Anyone know the biggest tires that can be put on 22" GM rims with a RC 2.5" level while having no rub and no offset?
I know this has probably been discussed many times on here but I have yet to find a clear answer. I have a '14 crew cab sierra all terrain and I am going to get a 2" leveling kit from rough country. What is the tallest tire I can fit on my truck once I install the leveling kit? I'm looking more for height, I like the width of the stock 275 55 20 tires. I will be installin the tires on the stock all terrain wheels. Any complaints with the RC 2" leveling kit on the newer trucks? I installed one on my '09 sierra when I had it and didn't have any problems.
275/60 with 2". I think you can do 275/65 if you do the 2.5".
If you like the stock width, you'd probably be safe to go with 275/60r20s or MAYBE 275/65r20s
Anyone having ball joint issues with the 2.5" kit? I have the 2" kit and am not happy with it. Going to add the other .5 inches soon and wondering if I will have issues with ball joints?
You'll be fine at 2.5" i wouldn't go any higher without doing a proper suspension lift.
Finally finished all the mods, here is some info for those looking for it.
- 2inch rough country leveling kit
- 305/55/20 Nitto Terra Grappler G2
- 20 inch Fuel Maverick Wheels with a 20mm Offset
And before any one asks, No rubbing on the fender lining and suspension at full lock. I also didn't trim a thing.
Nice looking truck! That's pretty much the exact same set up i'm looking to run. Any chance you could upload some more pics? Maybe one down the side, or from the front showing the stance? Thanks!
I know I asked before but didn't really get an answer.
Can I do Fox coilovers at Factory height and then use a spacer to get my level? I assume fox's would improve ride quality greatly but if they are too compressed they'd be stiff. Using a spacer on them might be the best of both worlds
2.5" lift, also came with a spacer to do 3" lift in the front. Then I put Firestone airbags in the back to adjust the ride height in the back when I haul/tow. Keep about 10psi in them and it lifted the back around 3/4-1" so I have a little rake in it. Tires to come here soon and maybe rims. Also thinking of doing a 1.5" body lift.
Before:
After:
Would you. Happen to have more pics?
18" problems haha I read that 295/70/18 rub with RC 2.5" on stock rims. I love the Z71 rims do i went with the safe bet 275/70/18 Cooper Discoverer. Love em
2015 Z71 Silverado 5.3 V8
Bilstein 5100 adjustable strut 2" Level Front
Bilstein 5100 Rear Shocks
Toyo Open Country AT2 275/65/20
MHT Fuel Nutz 20x9 wheels
Magnaflow 18" Dual Exhaust
Zero Rub
Couple of pics including a Before and After
Edited by second2none
    smandy
    smandy
  • Who's Online   2 Members, 0 Anonymous, 536 Guests (See full list)
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
