Definitely. I'm thinking 0.5-1.25" top hat with the 5100s. I have the shocks ordered. It's just a matter of adjustment w/ installation now.
I have to get a front and rear spacer as well, considering the rough country kit and selling the 2" lower spacer.
Exactly the kit I used and sold lower spacer. Good luck! Well worth it.
Just contacted Rough Country and they sell these parts individually but you have to call. Therefore there is no need to ditch the 2" spacer. Just an FYI for everyone.
Part # 1306 is the top hat (0.5" spacer) only. $29.99USD
Part # 6532 is the 2.25" rear block and u-bolts. $59.99USD
I was planning on running bilsteins with lower spacer. Was looking for 2.25 inches or so. Not 2.5. Plus cognito uppers. Why do you suggest top spacer instead of bottom? Still getting schooled on IFS front suspension. All other trucks I had were solid front axels
Thanks in advance
I'm running similar setup on my '14 HC. Except my 5100s are set to highest setting (1.8") with a .5 in spacer on top in front. And swapped out stock block (1.25") for 2.25" block in rear also with 5100s. Running 295/60/20 on stock high country rims. Barely rubs, and I mean barely, inner liner at full lock. Sits about 1/4"-3/8" higher in rear. As Big Whiskey stated, you can run bigger Timbrens or Firestone Airbags in rear to help with squat while towing. 02f7e2da525089a64b292072e95730c9.jpg
Your truck sits exactly how I want mine. Nice ride. Those tires measure out at around 34" tall correct? I would do the same height but on 18" rims
I did try the 2nd setting before the top. A little stiffer ride on top setting that I noticed but that's expected as I added 10ply tires at the same time. My opinion avoid the lower spacer with the 5100s if you can since they are designed for height adjustment. Anything over 2.5" your at higher risk for premature ball joint issues. All depends on how much clearance you want Really.
2.5 isn't the magic cutoff where nothing happens, anything over stock adds wear, the higher you go the worse it can become. A 1.5 inch is adding some wear, a 2.0 is worse and so on. Some people never experience anything, others wear out in 40k miles. Depends on what the truck does, many are just street queens and don't have a failure so they say 2.5 is safe but at 2.5 it can cause premature ball joint wear among other things.
Tyler
2.5 level front 2inch block in the rear. 20x10 -24 on 33s. Only slight rub on full lock reverse.
Sent from my SM-G935P using Tapatalk
Great info , I appreciate your help. I am looking for a moderate level/lift utilizing the bilsteins and a small block. I like the look you created, I will do something very similar.
Tyler
Don't disagree with anything you state here but I didn't say it was a magic cutoff. Simply stating due to angles of ball joints, typically anything over 2.5" level substantially adds greater risk for premature wear due to suspension geometry. Nothing is "safe"
Can you post a pic of it at full crank where it rubs? I want to run a 2.5 rough country on -24 20x10 and 295/55 instead, hoping with being half inch less it will not rub much if at all. Truck looks great
Thanks. Correct, I believe the finished height on the AT2s in that size was like 33.9" on Toyo website. Ive got over 11k miles on them, still look brand new.
Big Whiskey, Thanks for your help, lots of information I just wasn't sure I was reading it correctly. My wheels are stock 18" with p265/65r18 goodyears. thanks again for your help.
No problem. With a level kit and your stock 18" rims, you have a lot of tire options. 275/70/18, 285/65/18, or 305/60/18 will fit easily (and will actually fit on a stock truck). You should also be able to run 285/70/18, 295/65/18, or 305/65/18 without much trouble. And, 295/70/18, 285/75/18, or 33x12.50x18 might clear, but could require some trimming (or might rub the sway bar at full lock).
I have 285/75r18s on my stock wheels. No rub on sway bar or anything. Very minor rub on the carpet (at full lock) at first, but not an issue. Measures out to a 34.8 x 11.50.
That's pretty sweet. Those are big tires! I didn't think that size would rub the sway bar, since they're not much wider than stock...but thought they could rub the fender liner or mud flaps.
They are definitely beefy looking for sure! Lol. I love it though. Looking at it from the side you would think it would rub the flaps or fender liners pretty good but it doesn't.
360eb3b897685c2bdcefce8dcde2b984.jpg92eb4aff39cb467076731d6a61a25df3.jpg56b7343358d3dd6540c36f5ffcf6052c.jpg027e30d127c2939d70a6bf305663a025.jpg
Yeah, those look gigantic, haha. They look like they'd rub for sure!
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
