2.5 is safe? Yeah it looks good and if it is strictly for the street it could probably last for a long while to but if your suspension could talk I am sure it would bu cussing, it is only incrementally better for your front end than a 3 inch kit...
Tyler
Anybody running Mickey Thompson LT305/55R20 Tire, BAJA ATZP3 on a 2017 Midnight? Had those on my old truck and thinking about buying them again.
I am getting the 2.5" suspensionmaxx installed on Friday, I know it has been covered a few times but I have held off on getting tires since I want to know the best (biggest) tire size to run without major trimming. Based off a few of the set ups on here I am planning to run 275/65r20 on the factory wheels (+27 offset) yet does anyone have any more insight on this? Would I be better off going a different route?
I'm gettin the RC 2.5" soon, trouble is, I can't decide which wheels to go with for my tungsten metallic.....apologies for the minor threadjack
Edited by Jaycreek7908
Motofab 2.5 Installed, needs bigger tires now...
18527975_10155565329107323_6032379839735
What tires did you go with 207?
I have been holding out still, I was hoping to get some more feedback from other members. Now that the truck's leveled I need to get something ordered, I am pretty sure 275/65/KO2's will be the move.
Yeah the KO2s, Toyo AT2, Nitto Terra Grappler, Cooper AT3 or a similar All Terrain tire minimize the chance of rubbing. More aggressive MT or RT tires will most likely rub.
What are you running for a set up?
I have a 2.5 inch level kit with Bilstein 5100's set at 0 lift with Toyo Open Country RT 33x12.5's on stock All Terrain 20's. Have slight rub at full lock while turning in reverse.
If you like the K02s check out the falken wildpeak a/t3w tires. I bought a set about a month ago and I love them. They look similar to the K02s but at a much better price and have a 55k mile warranty. I only paid $170.99 each for LT285/70R17 10 ply at discount tire since they price matched a sale I found online.
http://www.falkentire.com/tires/light-truck-suv-cuv-tires/wildpeak/t3w-tire
Just had my leveling kit installed today!! I love it!! 2017 Silverado 1500 LT Allstar Edition
Excellent choice.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
