Sharp looking rig! What are you running up front? And may just be the angle, but anything in the rear?
Sorry meant to quote you.
2" level in the front +1" block in the rear. 275/65-20 (34") tires.
Rough Country 2.5" and 35x11.50 Nitto Ridge Grapplers
Yup! Made my new setup pretty easy to decide on.
My thoughts as well.
Considering these are bigger than a 285/65/20, and everyone says those rub, I just don't see how it's feasible without some rub.
Well the air dam is removed so that helps, but it looks like he has positive offset, so that hurts. I would say that it does rub somewhere. Probably on the rear inside of the front wheel liner.
Just got my leveling kit in last night!! Cant wait till I install them over the weekend!!
I decided to go with the 2.5" kit
OK, I'll bite. Where do they rub?
it rubs the sway bar at full lock. I cut the inner fender liner so there is no rub there
Edited by THE_Engineer
anybody got picture with a 2in front and rear with stock tire size... im buying the rc 2.5 kit but i think it would look weird with stock tire at 2.5 so im thinking going with the 2in f/r like my old truck was
This is a 2" front w/ factory tires. I don't think another .5" would look that bad. when time for tires just go up to a 33
you got the 2in at the back too??... i wont put tire on for a while since i got ko2 with the truck
No, just the fronts. Thought it would give you some idea of what it would look l like. My wranglers have 23K and about 10K left. cant wait to upgrade tires.
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
