1 hour ago, Daly said:
Yeah it's not the height of the tire, it's the width that cause a rub on the sway bar, control arm or fender. The height will usually only cause rub on the fender.
yep, I agree. There's a large variance in what tires can fit each of these trucks, and every case seems to be different. I understand offset is critical here but one persons fitment is another persons nightmare it seems.
Installed a MotoFab 2" level on my 2018 Sierra today. Took a little over 2 hours. Only ride difference is I can feel small bumps like a gravel road a little more. No difference on pavement. Love losing most of that factory rake. Will be looking into 33's at some point down the road.
Before level:
After level:
Wonder why?
Not sure. He had rub on the carpet liner. I had rub on the cab body mount. Strange because the wheel offset was identical. He was running 295/70/17 and I had to size down to 285/70/17. I still ended up with zip tied and trimmed ponders and mud flaps.
I also subject my truck to a workout off-road. Most of the individuals here who claim no rubbing are in a parking lot or doing a 3 point turn on flat ground. Different animal when your suspension is flexed.
  • Haha 1
I have 295/60/20 with a 2" level.   I have not gone rock crawling or anything like that, but I am in the dirt on jobsites at least a few times a week.  Sometimes on nicer dirt roads, and other times over piles of dirt, slopes, etc.  The only rubbing I can find is just on the sway bar at full lock.  Pretty much every GM that I have had with larger tires has rubbed there and it has never been an issue.  The tires come really close to the liners but there is no evidence of rubbing there yet.
Edited by 24v
2 hours ago, jgraves13 said:
Has anyone fit 285/75/r17s on a 2" level? I'm going to be doing bilsteins at the top setting and debating between 285/75 and 285/70
It all depends on offset and wheel width. What are you planning for wheels?
285/70/17 on 17x9 +6 on my truck with bilsteins @ 2" clears with no rubbing, it is close to the fender liner/flap  though.
Edited by tanner709
285/70r17 at 0mm offset needed trimming to not rub at 3” of lift.
Will be going with method nvs, specs:
17x8.5
0 offset
4.75" backspacing
Got any pics of your truck?
Rough Country 2" kit on my truck.  As measured, there is 1/4 inch of rake but, man, does it look high in the front.  Parked on even a very slight incline the nose definitely looks higher.   I am strongly considering the RC 2" rear block to eliminate this.
what wheel tire setup is that? offset? size?
I have the rancho quick lift struts wheels are 20x10 -12 offset fuel Mavericks and tires are 305/55r20 had a slight rub at full turn going up or down a driveway
On ‎2‎/‎24‎/‎2018 at 10:39 PM, SuperAllTerrain said:
I've seen some tall CB antenna's but that thing is unreal!! ;)
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,367 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
