On 5/1/2018 at 12:54 PM, 17SLE said:
Here is my truck after the dealer installed a 2.25” level. Put some 285/70/17 Mickey Thompson P3’s on it.
Can you get a picture of you upper and lower NJ angle and also your tie rod angle
I just installed a 2" BDS Level kit, because I got it here in the classifieds for cheap.  I may add another .5" at some point.  Stock wheels and tires for now, with 2" spacers on the wheels.  I'll be adding a Zone Add-A-Leaf (and put my cap back on), and 305/65-18's.
Edited by Ron505
So I need peoples input. I have found a temp setup so suit my needs for a few months.  I'd like opinion
2.5" motofab level.  Wheel is 20x9 +10 offset on a 33x12.5?
What year truck do you have? I have a 17 All Terrain with the same set up but with et37 and 1.25" spacers and still rub at full lock on liners. My offset is about +5 with spacers. You'll rub slightly more than me if you have a 16, 17, or 18.
16 regular cab
Just now, Nasty said:
16 regular cab
You should rub liners but should also clear the upper control arms fine. Liners are easy, either trim them or pin them back. Good luck!
And I was wrong. It's a 295 55 20
Has anyone done the Readylift 2.25" kit with UCAs on a 17 Silverado and run 275/65r20s?  I searched and couldn't find that exact setup.  Unfortunately, I have the stamped steel control arms and everything I read says they are trash with a level so I figure I should go with something that swaps them out.
Alright so ... are 275/60/20 going to ‘look’ too narrow when I level? [emoji51]. Pretty set on this size as I feel it’s a good price and modification compromise.
Leaning towards the Duratracs for daily driving (city:highway)
I would go 285/55r20
9 hours ago, Aaron1085 said:
Alright so ... are 275/60/20 going to ‘look’ too narrow when I level? emoji51.png. Pretty set on this size as I feel it’s a good price and modification compromise.
https://tiresize.com/comparison/
285/55R20 are smaller than 285/65R18 (by 1/3 inch tall)
check this out...that size is really close to 285/65R18...i think it would be fine...but as far as Duratracs...many people love them, I am not a fan...when I got my truck, I swapped them out for KO2s within a month...
So...I see people post (here and other places) shots of their trucks with 2", 2.25", or 2.5" and each will claim it sits perfectly level...sometimes I see a post of one with a 2" and I think it looks great then I'll scroll down and see one with 2.5" and think it looks great.  I do not want my '15 Silverado Crew z71 to look like the front is higher than the rear.  A buddy of mine said a 2.5" Motofab had his sitting perfectly level (by looks and measurement) but then I see Ron505's post of his 2" BDS and it almost looks like the front is slightly higher. lol
All that to say...I'm not going to be disappointed with a 2.5" Motofab on the front, am I?  I.e. it'll sit level?  Stock wheels/tires for now...will go slightly bigger on tires when I replace 'em down the road.
MHardiman90's looks great to me (looks level, etc.) but I guess I'm just on the fence and wanting to make sure I'm not going to show up when they finish installing it and regret something.
That's because in reality .5" from 20 feet away isn't noticable. I think you'll be fine with whatever you get!
Yeah, I guess you have a point!  I'm probably overthinking it lol thanks.
Anyone fit 295/70/17 on a 2" level? Not many pics online and trying to see how they look compared to 285/70/17
I just got done with my truck. 295/70r17 Toyo RT’s on method NV 17x8.5 0 offset with no rubbing. No trimming, cutting, or even zip ties on the liner. 2.5” lift in the front with king coilovers. New camburg UCA’s also 5d79f27b1905767fd09396e508558b16.jpg3eb2a6371dd608075375b90d3da03cee.jpgc0bdf6b40a421c7e421ea95a081dc374.jpgc0bdf6b40a421c7e421ea95a081dc374.jpg
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
