Rancho quick lift or fox 2.0 performance? Rancho quick lift kit is about $500 for front and rear while the fox 2.0 is about $1100 for front and rear. Best bang for buck?
thanks
Edited by Clemsontiger88
I didn’t see many good reviews for the Rancho quick lift struts. I just leveled my 2018 Silverado with the Fox 2.0’s and Rexlez uca’s, pretty happy with the ride but I think I may add a top spacer to get another 1/2” up front. Haven’t done anything to the rear yet.
I’m running 285/60/R20 Toyo RT’s on 20x9 ‘0’ offset wheels with a slight rub at the rear of inner fenders. The extra 1/2” should take care of that.
Edited by SSchup
add photo
On 7/9/2018 at 3:48 PM, thsoccer3 said:
I still have not diagnosed my "knock" noise since installing 2" front level.  I chose the "donut" style spacer that mounts to the shock upper.
My noise is a single knock when traveling slow that sounds like something is shifting on the driver side when going from forward to reverse.
I am beginning to think I possibly did not grind the factory bolts flush with the top of the new spacer and there may be a small gap that is allowing a forward / backward shift.
My next plan is to completely take apart the driver side and start over.
Any opinions?
I know your post was over a month ago but...are you sure the noise is from the front?  Since putting a 2.5" on the front of mine I have noticed a noise at the rear of the rear leafs - both sides. Can grab the hand hold at the rear corner and move the truck side to size and it'll do it, too. Still trying to come up with a solution.
This may be different than your issue...or maybe not.
Anyone else experienced what I've described?
Link to UCA? Never heard of that before
On 8/16/2018 at 9:14 AM, Dirt-Rado said:
These are all 285/70/179537e3339233ae4e343b7026f9650321.jpg
These look like 285/75-17.  I have 285/70-17 and your tires look noticeably taller.
Yes. They are all 285/70/17
Just put 315/70/17 on and now this is the look 749667cb6d97132ba0576548c4864d2d.jpg
Love the blue mrskiff.  Reminds me of my old indigo blue 97 Tahoe Z71 two door.  Had the grille, bumpers, mirrors, and handles color matched like your Silverado.
Looks fantastic IMHO.
2" RC level spacer
285/70/r17 duratrac on method roost wheels
No rubbing
Do you have any side shots without the wheel turned?
Sorry, I dont.
Just took one
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
