IMHO, Because I’ve had both on the same truck. The Ridge Grapplers are much more rugged looking than the KO2’s, very much make the look of the truck. The KO2’s seem to have a bit softer ride to them versus the Ridge Grapplers. Another thing is that the Ridge Grapplers are bigger tires and will take up a bit more room, 1/4”.
My experience with the Ridge Grapplers, over curbs, curb rashes, zero sign of anything. The KO2’s will show everything. That’s why I’m thinking they’re of a softer compound.
I had the KO2’s on for a few days before returning them due to vibrations at high speeds. KO2’s are well known to have some of those issues in the Jeep forums.
I went with the 285/65r18 ridge grapplers and 2” level. Will be in the shop on Monday. Ridge graps were cheaper too!
Are you running stock wheels? If you are, be prepared for serious rubbing. I had to buy new wheels with +1 offset. In a couple of weeks it’ll be lifted. [emoji6]
He has 18" rims, not 20". 285/65r18 fit fine with 2" level
My bad
Anything smaller than a20” is smaller, sorta wish I went with 18” wheels mostly cause you can find C rated or D but once you get a level or lift, starting with a 20” you’ll start heading into the E and F rated tires. 285/60/20 Nitto Ridge Grappler is close to $400 each, installed with warranty.
On 11/1/2018 at 2:25 PM, Bushleaguechew said:
How’s the rubbing? I tried that wheel and tire combo at 3” of lift and it was hitting the cab mount behind the fender liner.
Honestly, I don't rub that bad at all. The only rubbing issues I have are at full lock and even at that the tire just barely rubs the carpet fender liner. And I mean just barely touches it. I had ordered a 1.5" body lift that I thought I would need to clear the tires but they fit just fine without it. I take it off road every once in awhile and it does fine. I think it comes down to the offset I guess. I have +18 offset.
For those of you who have a 2017+ and installed 2.25" level without changing the UCAs, have you had any issues. Dealer is offering to install a ProComp kit without UCAs and keep my warranty in tact but I don't want to make the truck unsafe even if they keep the warranty. What good is a warranty if the truck is totaled?
On 11/2/2018 at 1:32 PM, ShubiSnax said:
275/60/r20 Duratracs
I dig it. Any rub with this setup? Are you running stock UCA? Is that a 1.5" level? Thanks
Running a procomp lift will included diff drop which doesn’t need new UCA’s cause with a diff drop your UCA’s will be fine for a while.
You should look at CST suspension, much better quality and doesn’t make your track widen up front like it does with all those knuckle replacement kits such as BDS, ProComp. A couple guy on this forum brought it up and I jumped on it.
Sent from above
Running a procomp loft will included diff drop which doesn’t need new UCA’s cause with a diff drop your UCA’s will be fine for a while.
Sent from above
The procomp is just a 1.5" top spacer and .75" spacer on the bottom. Just a regular level
That’s exactly what I’ve got but I immediately noticed right after I bought it and leveled it with stock tires then the headache started, bigger tires rubbed causing me to spend $3K on new wheels and tires. I’m looking forward to the lift cause apparently it’s going to ride like stock again.
Sent from above
Just dropped the truck off. Here’s the before 40bff0a952a20ccaaa2be7bcccd88916.jpg
What are you having done?
Sent from above
I have a 2017 and have the ProComp 2.25" level. I ran it with the stock UCAs for about 20k miles without any issues. I got my 2017 in August of 2016 and none of the levels were offering replacement UCAs. I added cognito UCAs because I got them used for a good price. I'm not saying you wont have any issues but I'm not easy on my truck and the ball joints were fine when I took the stock UCAs out.
The ProComp kit is just a level and doesn't include a diff drop. It is the exact same kit as the Readylift 2.25" level just in a different box and costs less. Now Readylift is offering replacement UCAs with the kit. 7fdd87731ce40372b9d3b6d7ad7fbf8b.jpg
Sent from my SM-G950U using Tapatalk
    xdieselmechanic
    xdieselmechanic
  • Who's Online   4 Members, 1 Anonymous, 698 Guests (See full list)
    • There's some truth to the above, but also, she's selling fullsize trucks and bread/butter CUV's like hotcakes, meanwhile, extracting GM's pickups from the deep discounting sales game.   GM's stock has held its own during her tenure, and the more recent buybacks are delivering cash back to investors and signal confidence in their direction forward. Even with the EV losses.   GM is an example of a modern publicly traded company. The #1 goal of any publicly traded company is to deliver the most value possible to shareholders. Despite being a car company, building the best car isn't GM's path to delivering maximum shareholder value.   McDonalds doesn't make the best burger, or the best coffee.   I've mentioned in another thread, I really don't / won't ever understand Cadillac or Buick in a modern context. Both brands are completely dead to me. I'll cede that the Escalade is a nice SUV, but the brand and nameplate mean nothing to me, and GM will never persuade me to pay north of $170k for a gussied-up Tahoe or Burb. Other people don't mind doing that and that's their purview.   The C8 shares absolutely nothing in common with any other current Chevrolet or Corvette on the market. Since its introduction 8 years ago, it's developed quite the following. It did what other Corvettes couldn't do: reduce the average age of its buyer. GM has something there, and I see them investing in the car. They'd better not mess that up.   We've successfully derailed Grumpy's thread again, but I think this one is meant to be more of a random thought thread so a little wandering is probably OK.
    • Sliding doors ftw   Also, Sienna ftw as well.  The in-laws got a 2024-2025 recently when their 2019 sienna was totaled due to a deer back in June.  They've been getting 38-40mpg on the 65mph highway they live on.
    • Forgot to mention that this started after changing the oil I use mobile 1 full syn with mobile one filter but I did add pro lube additive and was the first time doing so and is making me wonder just can't see why that would matter
    • I apologize for long post put going to try to explain everything. Parts replaced so far: Cam sensor Crank sensor Cam phaser valve Cam phaser solenoid Fuel pump Maf 1 injector Pcm Pdm   So about 2 weeks ago coming off the highway my 2007 yukon xl with the 6.2 stalled and would restart. Had unit towed back to house and I messed around with relays and unit started. Drove it the next day and same thing. Had it towed again. Scanned unit and had code p0300 with misfire data showing mainly cylinder 7 but I know that won't cause a no start. Measure fuel pressure and found only 42 psi replaced pump to have unit stall again and not restart. This time I stayed on back roads and just waited for it to restart about 30 to 60 min. During this time I found I have no injector pulse but have good power at injectors. Started unplugging 1 injector at a time and found when unplugging cylinder 7 pulse came back so i changed injecto and same issue. Turns out unit just happen to ready to start at that time. Scanned into unit and found no reason for the pcm to take away injector pulse so I replaced the pcm and same issue. I figured timing sesnor controlled the injector pulse so I replaced both sensors and while I had the water pump of i replaced the vvt components while i was in there. Read multiple people have luck chaging the maf for this issue so I changed it. Unit still stalls to this day and loses injector pulse on the ground side when it does. Have noticed watching the live data the pcm is request injectors to fire via injector pwm value. I have redone the ground wires at the left bottom of the block knowing this was the ground location for the pcm but still no luck. I am a mechanic by trade but this is having me pull my hair out. If anyone has something to have me check I will gladly im not much of a parts thrower but im about to load the cannon
    • Actually.  Wait.   I just re-read your original post.  Are you talking from INSIDE the truck you have to hit unlock?  Or from the key fob?  I had assumed from the key fob.   IF you are talking the inside unlock button, I assume you are shifting to park and its not unlocking the doors?  If so, that is changed via the settings page in the radio.  Go to SETTINGS, then VEHICLE and then it should be under LOCKS or DOOR LOCKS or something like that.
