14 hours ago, acinquegrana said:
Pinion angles don't "seat themselves".
You beat me to it, I was going to say the same thing.  How does a pinion angle seat itself?  :shakehead:
Well I finally got to a point in my schedule to take a picture of the rear blocks but I can’t get it to upload. No matter, they were used two inch blocks that were not tapered at all. I took them out and reinstalled the stock blocks for now. I have ordered the two inch blocks from RC and will install them as soon as I can. The vibration seems to be gone I believe. I haven’t really driven the truck much since I just did the swap today. I will post again later in the week to update. Thanks for all the helpful comments.
On 1/24/2019 at 11:16 AM, SSMUFF said:
Nice truck (twin).  You say you did the 2" up front only but in your signature you mention the 2.5.  Did you do the full RC 2.5 kit or did you do just the less expensive option and lift the front only?
just the front only
Reporting back that after shocks settled I have a slight rub with 295/70r17 Toyo rt’s and method 17x8.5 with a 0 offset. Shocks were set for 2.5” of lift. The rub is very minor and only at full lock in either direction. The rub is only on the felt liner and could easily be fixed with zip ties.
No. Coil overs are adjustable in place. The quicklift is just an extended strut. And IMO they ride like shit.
Ahh ok I gotcha but is it a better ride than spacers?
There’s nothing better riding than coilovers
Sent from above
I found the quicklifts to be about the same as the spacers when I did the swap in my 2012. On my 2014 I went to bilstein and found the ride to be better. On the 2014 I did the bilstein 5100's set at 1.85" with a 1/4" spacer, and I found the ride to be pretty much the same as stock.
Sent from above
Not doubting that but the CST coilovers cost 1200$ thats a little much
I know you’re not. You get what you pay for. You can get a set of Fox 2.0 setting to 2” max, approximately $900. Pop out your whole stock setup, put them in storage and enjoy your new Fox Coilovers. Bilstein adjustable front struts are the cheapest route but not as smooth as coilovers.
If you’re in a hurry and don’t want to save up then the Bilsteins is your comfortable cheapest route or save a few extra hundred and have the coilovers.
Sent from above
For those that are tracking my vibration situation. The vibration didn’t go away after removing the rear blocks and restoring the rear to stock. I plan on removing the 2.5 inch kit from the front now to see if it returns to normal. If that doesn’t work then I will take it to the dealership that I bought the truck and hope whatever is wrong will be covered by warranty. My truck doesn’t even have 5 thousand miles yet. I am now sorry that I ever messed with it. Just wanted it to set level and be able to fit a little larger tire.
did you get a front end alignment when  you lifted it?
On 1/31/2019 at 10:57 PM, Slick66 said:
Yes I had the same shop that did the install do the alignment.
When the shop did your leveling kit, did you have a 1" diff drop added as well? If not, the CV's are probably causing the vib. Simple install, takes about an 1.5hr my yourself and that well get you back close to factory angles while still maintaining the leveling kit. The diff drop spacer kits run about $40.  Just my 2 cents.
    • The not as clean as one would assume theme with the new engine oil, that reminds me of comments over the years with mechanics not always being so on board with filling an oil filter, not from the center anyway due to that typically being the clean side of the filter, danger of some contaminant falling into the filter if not careful but the realization now that the oil may not be as pure as one had assumed it would surely be. Yes it would be possible to fill from the small holes but that means messing with something to prop open the anti drain back valve if the filter is so equipped and not damage that valve in the process. Me, I have hardly ever prefilled an engine oil filter however I have prefilled diesel fuel filters with a filter on a fuel bulk tank and for anyone that has messed with diesel engines with filters and units that have a limited or no way of priming them, putting on a dry filter is a bad day to say the least with those crappy systems. But anyway back to not so clean engine oil, indeed perhaps its not so bad after all that I have not made a practice of prefilling oil filters.    As Grumpy Bear commented on keeping things clean, that I really have to wonder what the typical practice is at a dealer or any other shop that changes engine oil, do they make sure to wipe or wash off the oil plug and certainly if it fell into some gunk or onto a dirty floor, or that they wiped the filter mounting flange and didn't go and use some dirty rag and end up adding dirt to the inside of the head of the filter mount. Or be careless in how they stored or handled the new filter and if they were bumping into items under the vehicle with the filter opening facing up and having dirt drop right into the filter and if so right into the threaded center that is on the clean side. The top side, did they clean away the built up gunk that may be around the filler before removing the cap or to be really careful at that point that something right close to the filler hole that was hidden under the caps flange won't fall into the engine. Or did they clean the funnel or was that just laying there covered in oil from the oil change before and dust kicked up from sweeping the floor stuck to the oil and now that will go running into the next persons engine due to just not cleaning the funnel as "they won't know anyway" attitude as that young guy is more worried about taking a break so he can go outside and smoke a joint. Just random points that came to mind when I think about what some hired personnel may do that the shop foreman has no idea of or perhaps the whole attitude of some shops may be "eh ... who cares, they will never know the difference anyway".
    • $3.69 for 87 octane.   $4.24 for Diesel in town.
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
    • I'm pretty sure it doesn't actually recalibrate the speedometer it just changes the wheel speed sensor inputs to the computer. The truck still thinks it has stock tires.
    • I apologize, I missed this post, at risk of going off CURRENT TOPIC.   I'm not saying it is BS, I'm questioning how much information is being held back. GM is NOT going to spell out exactly every parameter in the algorithm. Liability, intellectual property, etc.    I'm not naive enough to believe that it is as simple as revolutions, coolant temperature, miles, time; are you?    I don't do irrational either, and boiling the OLM down to four simple values that I could code in an afternoon (I'm not a coder) is irrational - unless it suits your agenda to ignore it.
